Since a few days, all my Yeelight lamps, the WiFi color version, are not available in the homey. Do more people suffer from this or do I perhaps do something wrong? Could someone help me?
On the iPhone app Yeelight, they work normally and lan management is also on.
Yeelight support has been removed from the following app:
And is now supported in a separate/new app.
If you are still using the old app, remove lights and add them with the new app.
Always read the changelog before updating:
“Support for Yeelights within this app has been deprecated. Yeelights are now supported through a dedicated app available in the app store. Please migrate your Yeelights to the new Yeelight app.”
very thanks for your answer. I already tried to connect them with the new app. But the homey yeelight app can’t find any yeelight. Do I need to reset the yeelights to factory default? I try tonight.
Thanks but still it doesn’t work.
LAN is on in the Yeelight app. In this app the light works. But when I want to add a light in homey. She said that there are no new devices found.
Deleting the app does not remove the devices. You need to remove them. Due to a bug in Homey (which will be fixed with firmware 3.2.0) you can not have the same device paired by two different apps.
No, you probably have to wait for version 1.0.3 of the Yeelight app which contains some fixes for pairing certain lights (specifically the ceiling5 model). It’s pending approval and wont take more than a couple of days maximum.
IN my case I had to factory reset my lights (in this case Yeelights LED strips). Looks to me product / firmware issue, as it started already some time ago.
Thanks, I already tried but still no new lamps showing in the homey app.
@athom homey
Maybe there is a way to delete the yeelight app and restore the old xiaomi mi home because the new yeelight app is not complete and fully tested. Next time it’s better to bring a beta version first.
@Randy_Kl I’m sorry you are experiencing issues. But out of +100 users you seem to be the only one which still has issues. So I would not directly blame the Yeelight app. The code of the new Yeelight app is pretty much the same code as the Xiaomi Mi Home app. Saying the code is not tested properly is just pure nonsense because of this. And even if that was the case, I’d create these apps in my spare time so a little respect for the effort would be nice.
But enough of that and lets try to figure out what goes wrong. First question, is your Homey on the same (sub)network as Homey? And do you know how to run an app from the command line, you could run the debug version of the app and that would tell me what is going on.
It’s an new router, nothing setup except some passwords.
IP-address router: 192.168.1.1
IP homey: 192.168.1.65
IP yeelight: 192.168.1.67
No VLANS are setup as far as I know
