Only thing that work is on/off
Hello
CAN You help me to integrate Xiaomi Déshumidificateur lite with homey Pro
How can find token , I try with Get token , but it’s impossible to connect ?
Thanks
Why I can’t connect the Humidifier JSQ2W, It gives an error: Device is unreachable: Cannot read properties of undefined (reading ‘toString’). The report 532f6121-0b85-4c9b-9336-76d7acd1ba3c
Please share the debug
I integrated the Smartmi humidifier v1/v2 (WLAN) as a Mi Smart Antibacterial Humidifier MIoT (WiFi) and now it runs stably.
Title: Dreame L10s Ultra – Room Cleaning Card Not Working (Room IDs ignored)
App: Xiaomi Mi Home (by Phuturist)
Homey Pro 2023
I’m having issues with the “Clean specific room(s)” flow card when using my Dreame L10s Ultra through the Xiaomi Mi Home app.
The card asks for Room IDs separated by commas, but the robot simply ignores them and performs no action.
I have tried:
The numbers shown on the map (1–9)
Possible MiIO internal IDs (16, 17, 18…)
Strings (“7”, “3”, “1”)
Combinations (“1,3,5”)
Different separators
Different rooms and zones
None of them work.
This seems to match the known issue where Dreame vacuums do not expose rooms in the same way as regular Xiaomi/Rockrobo devices.
Unfortunately :
- I don’t have that device myself, so it’s very hard to troubleshoot anything like that
- sadly, Dreame seems to be switching over to cloud authentication only, instead of Local control - Custom Component: Dreame Vacuum - #1232 by tasshack - Custom Integrations - Home Assistant Community … I think I read somewhere that even that option is being restricted as well, not sure now. Try your luck with the cloud based app eventually.
Xiaomi Robot Vacuum X20 Pro (xiaomi.vacuum.d102gl)
Changing the water does not automatically change the error status (water tank empty).
Thank you very much.
Unfortunately can’t do much without debug log … send it next time it happens
6dd842f8-b437-44e6-85fe-a361e6ba0401
Please try with latest Xiaomi Mi Home | Homey
Version 3.4.45 — Petfeeder - work in progress, Xiaomi Vacuum Miot Max adjustments
Hi there! Is the Mi Smart LED Desk Lamp Pro also supported? Have not been able to find anything about it within this topic.
Thank you!
It’s not but if you are able to add it to the Yeelight app, then you can try it with Yeelight Homey integration…
Hey!
I can’t manage to get the Xiaomi Smart Plug 2 token, so I’m unable to connect it to the Homey app.
I’ve already tried extracting the token from Xiaomi Home backups, but it seems that this model doesn’t expose a local token at all (MIoT-based device). Because of that, the usual token-based integrations don’t work.
Could you please advise:
Is it actually possible to connect Xiaomi Smart Plug 2 to Homey?
Does Homey support this device via Xiaomi Cloud / MIoT, without a local token?
If not, what would be the recommended workaround or alternative?
Any guidance would be really appreciated. Thanks!
Why this way and not eg. using GitHub - PiotrMachowski/Xiaomi-cloud-tokens-extractor: This tool retrieves tokens for all devices connected to Xiaomi cloud and encryption keys for BLE devices. ?
Here is a list of currently supported devices. As you can see, Xiaomi Smart Plug 2 shall be among them however please note not many people is using it….
You can always setup eg. Home Assistant and integrate it back using Home Assistant Community app.
I managed to successfully obtain both the IP address and the device token for my Xiaomi Smart Plug 2.
However, when I try to add the device in Homey via
New device → Xiaomi Mi Home → Xiaomi Smart Plug (WiFi)
and enter the IP address and token, the Test Connection fails with the following error:
“Could not connect to device, handshake timeout”
That usually means your token is not right…which method have you used?
For the token extraction I used this repository/tool.
I logged in using my Xiaomi account email and password. After logging in, I selected the DE server, where my devices were listed. From there I copied the token and the device IP address and pasted them into Homey.
In Homey I go to:
Then I enter the IP + token and press Test Connection, but I still get:
“Could not connect to device, handshake timeout”.
Let me know if there’s anything else you’d like me to check or provide.
Hm, and your Homey is on the same subnet/no VLAN as the plug ? You can try to provide debug log after you attempt to pair your plug but I doubt I will see there anything more then “handshare error”.
