[APP][Pro] Xiaomi Mi Home App
I can see Left/Right triggers in motor controller section, is that what you need to implement this functionality?
I was looking for Turn left, Turn right :rofl: OK, let me try.
Please try with Xiaomi Mi Home | Homey - 3.4.30 - if it’s still not working, send the log from the app and feel free to jump to the private DM conversation.
This works perfectly well, many thanks, you rock ! :partying_face:
Edit : fyi and for the next patch, left & right are inverted but that doesn’t matter (turn left option makes the fan turns right)
Shall be fixed in latest version 3.4.31, hopefully.
Did anyone, successfully or not, try to add the Smartmi Air Purifier 2 through this app? I’m considering buying it, but lack of Homey support is almost a deal breaker.
anyone already succesfully added the dreame x40? havent found it out yet sadly, see its supported but have no clue yet how to get the token when not able to add it to mi home app
Hello. All of my Xiaomi devieces keeps going offline. Do you know what can be the prblem?
Hello, I am experiencing problems with this app.
My air purifier always offline
Lots of functions missing from Xiaomi air purifiers.
Here several others including myself are missing the set fan speed on xiaomi air purifier 4 lite model.
Any of this that could be included in Homey pro?
Github HA
Yes, but checking out the code, implementing and testing the changes and then submitting changes via GitHUB for review for the particular driver.
GitHub - PiotrMachowski/Xiaomi-cloud-tokens-extractor: This tool/script retrieves tokens for all devices connected to Xiaomi cloud and encryption keys for BLE devices. - use at your own risk
Was it ever online? If not, you don’t have right token I guess.
No idea without log and more details.
It is the right token. I retrieved it the same way as I did before in my old home. But after moving and resetting my homey and re-pairing the device, the device is marked as online in the app in homey but the moment I try to control the device I get an error message.
I will try to replicate and generate a log tomorrow
I have a Xiaomi X20 Pro device. I got a token and tried to connect it to Homey, but I can’t find the ideal settings.
  • If I choose Xiaomi MIoT MAX, I get this error:
    “Device is unreachable: Cannot read properties of undefined (reading ‘toString’)”
  • If I choose Xiaomi MIOT, I cannot select rooms.
  • If I choose Advanced Dreame, I cannot choose between sweep, mop, or both, and I cannot set the mop intensity to “none”.
Also, I can’t find a way to do double cleaning – meaning the device would make plus cleaning: it would move in parallel lines from opposite directions.
The best option for me if I can change, and combine all of them with any combination:
  • Rooms
  • Mop / Sweep / Sweep & Mop mode
  • Mop intensity
  • Fanspeed
  • Maybe deep cleaning (duble cleaning with lef directions both)
Can this be solved in any way? If not, is there a chance that the requested features will be created?
That’s the only proper driver, please submit diag.
Sorry, I messed up. It’s an X20 Plus device.
I see that this is the proper driver: Xiaomi Vacuum Cleaner MIoT driver.
Suddenly the room selection isn’t available with this driver.
Yes, it’s not implemented, unfortunately I don’t own X20+.
It would require someone very responsive during potential testing knowing what to do or best provide access to Homey with port forwarding enabled. If you are interested, contact me via DM.
Hi! I’m struggling to setup this app for Xiaomi Wall plug. It worked previously but currently with the IP and the token connection is not working. I always receive timeout error. What can be the problem? Thanks!
I’m having the same issue with the Smart space heater. Finally managed to get the token, but I only get timeouts when I try to add the device to Homey.
