[APP][Pro] Xiaomi Mi Home App
Deleted both devices and added them again. Both devices have been updated to the latest firmware 4.1.8_0287. Now they write that they have no internet (apparently because of foreign dns server), but at the same time in Xiaomi Home all data is updated.
In homey after adding only pm2.5 is empty and that’s all. Sending repeated logs.
d232b9a3-f101-4300-a808-14b93449182c
OK, apparently capabilities are not being created as required, will have a look on it later
After update to 3.4.8 test
Great but missing diag. log pls as I sent you in PM. Also please continue in PM as this thread is not for individual support cases, not everyone is really keen on this. Thank you.
A huge thank you to the developer of this app for solving the Clear Glass air detector problem and respect for the work you have done. This device is the only one available on the market that can transmit online with 0.1 degree accuracy the temperature to create the perfect climate in the house and it was lying in a drawer until you helped.
Again, a huge thank you.
Btw is it really still available ? Seems to be very nice device btw…was almost considering to buy one for my personal use (and development…) :wink:
It is available in next revision CGS2
There are two minus of this device:
Update only buy china vpn network and china DNS (some times its work under Europe internet)
Many people are annoyed by the fan humming, like my wife. But it is only needed for PM particles and this is solved by blocking the fan with a paper clip, for example.
But the low cost as well as the functionality covers it all.
For example, I use tVoc when my wife lights scented candles. If the reading rises, the exhaust system in the house is switched on to high mode. It can also be used as a fire alarm.
And the reason I couldn’t find it is probably different name - https://www.aliexpress.com/item/1005006116110621.html - it’s called Qingping Air Detector 2 - 青萍 Qingping
It’s very nice gadget but… the price :moneybag:
This a new model with replacement PM2.5 PM10 module, without problems with vent.
Previos version i bought in half of this price
Has anyone gotten the Xiaomi SmartMi Humidier v2 (Wifi) device to work in Homey? The installation is successful and the test during installation passes (IP and Token are ok), but it still doesn’t work properly in Homey. I get a “device in unrecheable” error.
I don’t but have you submitted log ? I’m not sure I have seen anything…
I haven’t sent it. I haven’t done it before and I don’t know how to do it. Where can I find instructions?
When you check device details in Mi Home app ? Isn’t it showing deerma.humidifier.jsq2w ? Because based on log, I see Mi Smart Antibacterial Humidifier JSQ2W, which you have added via wrong driver, try to add it via Mi Smart Antibacterial Humidifier MIoT driver as per Supported Devices · shaarkys/com.xiaomi-miio Wiki · GitHub
Now it works correctly. Thank you very much.
I have the xiaomi pet feeder 2. I can add it with the token but then i get the error cannot read properties. Is this device not supported? And if so then maybe it can be added eventually.
Have you added it using right driver? If so, submit debug log…
@Sharkys
I don’t think it is then. Maybe only the pet feeder 1. Not sure.
Send the log
5efc6aeb-e885-4b87-92a3-29635c559e8d
Can you install Xiaomi Mi Home | Homey and remove and add again the feeder and again provide the logs ?
0c3a0ffd-d228-49b9-a3a6-6081958f7f92
No need to keep posting ID here - have you removed and re-added the device as I asked ? I don’t see that in the logs. Also are you sure you really used the right configuration - IP and Token ?
