Just donated 10,- as committed. Thanks for the great efforts so far!
2023-03-07 - v3.1.1 - TEST
This release is a complete rewrite of the app including many breaking changes. The app has been fully rewritten with SDK3 to make it futureproof. This new version also merged the devices from the community app Mi Homey. Some previously paired devices might continu to work but please re-pair your devices and/or fix your flows before reporting any issue. If the issue persists after re-pair please report it on the community forum or Github.
I have just published a new test version to the test channel of the app store and I’m looking for people to properly test this version as it will contain bugs. As the release also contains breaking changes the only way to properly test it if you encounter an issue is by re-pairing the device and/or fix your flows and test if the issues still persists. If so, please report it here or preferably on Github .
If you want to go back to the live version you will have to re-pair and/or fix your flows again as both versions are not fully back- and forwards compatible.
Updates in 3.1.1
- Fix for Philips Lights not initializing
- Add Join / Pair button to Gateway WiFi
- Turn on/off Gateway WiFi light based on dim value
- Possible fix for error on Mi Air Purifier 3H
- Fix issue with docking for Robot v1, 1S, 5S and T6.
The test version can be installed through this link: Xiaomi Mi Home | Homey
All works, great stuff, as always, thank you
Even seems I didn’t have to remove lights ! ![]()
However with join/pair button, I tested adding one of the Xiaomi temp. sensor WSDCGQ01LM(…they were really unreliable with Homey) and seems while original app shows updates, the Homey integration with added device not. Sent diag. if this helps to discover something more - eg. even for others Zigbee type devices.
Will test this weekend
Works fine with docking! Thanks!
Is there a plan/timeline at all of implementing the “room” cleaning feature?
Please submit a feature request with more details on Github so I can look at it once the new release is stable. Please describe in detail what functionality you want and how you want it implemented.
Updated the app to the latest 3.1.1 and readded my two Xiaomi fans (zhimi.fan.za4). Both can be found and added. But I can’t control them. When I press the power button I get an error “this.miio.setPower is not a function”
(Also added the purifier 3c for the first time. Works great. Thanks!)
edit: The device status doesn’t seem to update either. If I turn them on and off manually it still says on in the app.
Best would be to create Issue on GitHUB Issues · jghaanstra/com.xiaomi-miio · GitHub and eventually attach also Diag. code… I believe there might be more issues like this, considering the amount of rewrite that had to be done…
I also donated today:
Please create a Github ticket including a diagnostic report and more info (for instance with what driver you re-paired them with).
I found one possible opportunity to make the app better.
The lumi.sensor_motion.aq2 device is swithing off to quickly. Compared to the same sensor in Mi Homey, the same sensor in Mi Home App switches off when there is still presence detected in Mi Homey. So for switching the lights off, I reverted back to the Mi Homey App.
The same devices in both the Mi Homey App and the Mi Home App.
Do you mean “Disable motion alarm after” settings ?
You can configure this behaviour from the device settings where you can specify the Disable motion alarm after setting.
I do understand you have to ask for the most basic information. I should have given it right away ![]()
Nope
Will be fixed in the next release (there is no presence detected but turning of the alarm is just delayed).
2023-03-08 - v3.1.2 - TEST
Updates in 3.1.2
- Fix issue with humidity and temperature sensor not initializing
- Fix to take alarm duration for aqara motion sensor into account
- Added action card for gateway to set all different volume levels
- Added action card to room clean for the v1, S1, S5 and T6 vacuum driver (pairing other models with these drivers might work as well)
