[APP][Pro] Xiaomi Mi Home App
What do you mean by this, like vacuum robots ?
But also
For instance. The Xiaomi Mi Home or Mija eco system is huge and they keep bringing out new product variations that work slightely different all the time. Some products have been reversed engineered and integrated in other integrations. Sometimes this information can be used to add it to the Homey app as well. But as mentioned, I first want a stable base (SDK3 with merged functionality of Mi Homey).
I already looked at that if integrating those would be an opion, the code of this app is not shared on Github by the developer as far as I checked so no, I probably wont be integrating that 1-on-1.
2023-03-05 - v3.1.0 - TEST
This release is a complete rewrite of the app including many breaking changes. The app has been fully rewritten with SDK3 to make it futureproof. This new version also merged the devices from the community app Mi Homey. Some previously paired devices might continu to work but please re-pair your devices and/or fix your flows before reporting any issue. If the issue persists after re-pair please report it on the community forum or Github.
I have just published version 3.1.0 to the test channel of the app store and I’m looking for people to properly test this version as it will contain bugs. As the release also contains breaking changes the only way to properly test it if you encounter an issue is by re-pairing the device and/or fix your flows and test if the issues still persists. If so, please report it here or preferably on Github.
If you want to go back to the live version you will have to re-pair and/or fix your flows again as both versions are not fully back- and forwards compatible.
The test version can be installed through this link: Xiaomi Mi Home | Homey
Thank you @Phuturist , going to test for my few devices.
ALL - just might this script come handy : [HOW-TO][Pro][Cloud] - Tool to FIX (advanced) flows after removing and re-adding devices
It’s fantastic life saver in such situations. My advice - mark down the old device IDs before doing any repairs. :wink:
So surprisingly Xiaomi Gateway v2 (lumi.gateway.v3) added flawlessly (previously added as 3 devices, now as one) - I see however JOIN button missing (eg. when adding devices to the GW itself). Surprisingly even lux sensor works after more then 2 years ! :wink: Not sure if light powered off via DIM or powered on via DIM shall results also in Button switched off/on- it’s currently independent on light itself but button itself turn lights on/off.
I also got down-light “Philips” lights but after adding them (and also after automatic app update), I’m getting error when interacting with light - Could not get device by ID …sent also diag report f5c3c1ea-9865-4e90-8559-2c82d433ae62 (I hope that’s the right one from clipboard but if not, i guess you were notified)
Where is this button supposed to be? I thought adding devices to the gateway was done in the Xiaomi Mi Home smartphone app. I can probably add it if I know where to look for.
Havent really looked into this level of fine-tuning. If it’s desirable you can add it as feature request on Github so I can look into it at a later time. First make it stable.
Yes, got the report and know what’s wrong. Will fix that with the next update.
I had it available from the Mi Homey app v 1.1.12 - in device type named “Gateway | SOME_HEXA” (this is the name when added the GW) - GitHub - Maxmudjon/com.maxmudjon.mihomey: MiHomey App for Athom Homey or better com.maxmudjon.mihomey/drivers/gateway/driver.compose.json at master · Maxmudjon/com.maxmudjon.mihomey · GitHub
It’s far from anyhow important, it’s just consistency maybe - I’m any way handling it via flows, I guess that error existed even before.
Both created as Xiaomi GW v3 - Join button missing and dim values are not changing button on/off state · Issue #159 · jghaanstra/com.xiaomi-miio · GitHub
Awesome, thank you. :wink:
Wow… :index_pointing_at_the_viewer: :+1:
Like I said, a complete rewrite … :wink:
Is it any chance that Roborock S6 and above will be included in this rewrite, since Justine Harings Roborock is abandonded? :heart:
Maybe spkesDE will (re)create one, as he owns Roborock - S7…
But it’s true that in the current app you can add Roborock as well :
I want to get a S7, but I don’t own one yet.
Ou, sorry…that’s a bummer. But definitively, a little bit of OT, I can really recommend Roborock brand - it’s based on 3 years of experience with it, great device, very reliable.
The device can clean as it should. But return to dock not works anymore.
Tried one the device “property” page in the app. Also tried as part of a flow. No success.
What device? And on what app was it previously paired and with what driver? And what is the actual error. I need more info.
@Phuturist Can I request an icon change for the Mi Air Purifier 3H? The current one is a bit outdated and doesn’t fit the other Homey device icons really well.
I’ve made this alternative:
http://basvanderploeg.nl/uploads/mi-airpurifier-3h.svg
Xiaomi Mi Home version (probably 3.0.9, if it was the latest stable release, cannot promise it worked in that version for sure, used the room function in “roborock” app before, but had the device added to both of the apps in parallell, need to move due to missing sdk3 support on roborock app)
Roborock S5
Added by IP + Token (maybe all are?)
Polling frequency 30
Not sure of driver used.
No error, if in cleaning and i try “return to dock” action it just change state to pause
Created A report:
fd2a2785-3dca-4e94-8e96-96d58ed7f2ff
:moneybag: Bounty thread for updating Xiaomi Mi Home to SDK3 :moneybag:
I will post update as per info in this thread
(intentionally as new message to keep raising attention)
Beware there is already SDK3 compatible version - 2nd Alpha :wink:
Please don’t commit your donation if you will not keep up on your promise.
DONE :
Sharkys - €15 - done
Glenn_Seegers - €50 - DONE €25 :clap: + €25 if updated with the newer devices
JaccoStraaijer - €15 - DONE :clap:
caaaasper €10, DONE :clap:
Wout_van_den_Dool - €25 - DONE :clap:
M_a_r_c_o - €15 - pledge :clap: (confirmed via PM)
RonnO - €20 - DONE :clap:
Inunekko - €25 :clap: DONE
@Glenn_Dijkstra - €25 (in case of update of the original app) - :+1: DONE ??
To be done:
@Henk_Renting - €25 - pledge :+1:
@Jan_Peeters - €25 - pledge :+1:
@JPe4619 - €25 - pledge :+1:
Sum pledged : €250
Sum already donated : €150 or 175€ (based on updates in the thread - please update thread if you donated)
:face_with_monocle: Goal 399 € not reached yet :face_with_monocle: …but getting there :wink:
Paypal link - PayPal.Me (always rely on info provided by Jelger Haanstra - @Phuturist - double-check his Paypal links prior to donation)
Other potential donations not counted :
@Maurits - promise - done ?
Condition fulfilled : Xiaomi Mi Home SDK3 compatible version published - DONE
(but still in progress, also HP2023 tested !!)
In case of any disagreements, let me know by PM or by reply to this message.
Sure, will add it with the next release.
I found the issue, will be fixed with the next release.
It’s also tested and confirmed to work with HP2023 … :wink:
