[APP][Pro] Xiaomi Mi Home App
So I contacted Maxmudjon throught Telegram and he responded right away. We had a teamviewer session where he found out about my Purifier model and he confirmed that he will work on this in the next days. @Japper
Aah nice. Thanks for letting me know. Let’s hope that will also fix the issue for me.
Any news on a new release? It’s been over 3 months since I last had Co tact with the developer, he added a new Humidifier, but that version is still not released and the dev seems very unresponsive. I think I’m going to give up on this app and look for other solutions…
Yup, I had contact with the developer aswell and now he is no longer responding to me. Not sure whats going on…
I finaly got some contact with him and now he responded that he is too busy.
Then I offered him a small donation and he didnt repond anymore.
What a waste of my time…
And a pity that this app is no longer under proper support. Maybe another dev can step in and take over…?
Someone using a Dreame robot vacuum cleaner here? I was able to add it to Homey correctly, but I cannot control it at all.
Will support with some money too
Hi guys, I’m having trouble with adding the Xiaomi Roborock S5 Max. I have a token but still getting the error “could not connect to device, handshake timeout”.
I extracted the token with these instruction: https://www.youtube.com/watch?v=m11qbkgOz5o.
What did I do wrong? Some help needed.
New version 1.1.12 on Github. Mi Air Purifier 3H works !!!
Where do you see that?
Hmm maar in versie 1.10 staat dat de Evaporative Humidifer 2 werkt maar als ik die handmatig op Homey installeer en probeer het apparaat toe te voegen staat er ‘coming soon’…
I successfully added the 3H purifier with the 1.1.12 Mi Homey app from his github page indeed. However I get a lot of PING timeouts on the network and the app also shows timeouts on the device. Do you have the same terrible PING responses on your 3H’s?
2021-07-11 15_18_53-Opdrachtprompt
All other devices in my network are 1ms PING
How can I update to 1.1.12?
Using the Homey CLI install method: [HOW TO] CLI install method
Thank you! Noob question, I downloaded the “code” and extracted it. Installed the Homey CLI tools, logged in and navigate to the folder. What command do i need to use? And are the steps correct?
Yes if you navigate to the apps folder you use ‘homey app install’
No Ping request timeouts here
Thank you!
New version in the Community Store: https://store.homey.community/app/com.maxmudjon.mihomey
Changelog mentioned at the bottom of the page.
