Thanks for the detailed feedback and the log. I found that the color picker changes were not handled as one grouped update, which could cause Homey to receive partial hue/saturation values and reset the UI color to white.
I have made a fix for the Yeelight Arwen Ceiling Light D driver and added main light mode selection: Day, Night, Color, Flow. I also added ambient/backlight color mode support where Homey supports it.
Please test this after the next app update and submit new logs. I do not have this device myself, and the MIoT specs are not always fully accurate, so this may need some trial and error based on real device feedback.
All, I’m going to update production version next week, I highly suggest testing the new release prior to release.
Xiaomi Mi Homey App v3.4.73
This update brings expanded device support, improved device stability, and several fixes across humidifiers, vacuums, lighting, and appliance integrations.
Seems like not everything is send to the cloud… For now I can start, stop and pauze the device. And see when it is turned on or off ( it turns off when ready). I can even select a program to start remotely, but will never use that option from homey I guess.
For now I keep it like this. No idea if this device is used by many others
thx for adding it so fast to the main app!
pro failed to function following the 3.4.74 update. I did not notice it initially… Neither pro nor max triggered a ‘no water’ notification. Reverted to version 3.4.27.
hello Sharkys Please add zhimi.airp.cpa4 to the mapping_cpa4 in the airpurifier_zhimi_advanced_miot driver — same as xiaomi.airp.cpa4, same property IDs.
Could support for the Xiaomi Robot Vacuum S40 Pro be added?
Device: Xiaomi Robot Vacuum S40 Pro
Model: xiaomi.vacuum.ov71gl
I can add it but it gets “Unknown model (xiaomi.vacuum.ov71gl)” and it momentarily works but then shows “Device is unreachable: Cannot read properties of undefined”
