[APP][Pro] Xiaomi mi flora sensor/ropot app
Dunno if this helps, Jamie, but here’s a similar post about migrated (to Homey 23) unkown BLE devices:
Screenshot from 2023-03-08 01-06-44
https://athomcommunity.slack.com/archives/C04E9KJAD/p1678215245055259?thread_ts=1678211592.720489&cid=C04E9KJAD
Adding a sensor to hp2023 does not work. I can add the sensor in the mi flora app. I removed the sensor in the app and removed the battery to reboot the sensor. Any tips
EDIT: Maybe this fw update works for you @wesley_w @Jamie
Seems you are not alone, definitely report Ble issue to Athom I would say.
With the RC56 its working for me :slight_smile:
No luck for me at the moment… any tips? On rc57
Try again and again. the discover is quite messy still.
I replaced the Battery after that it came alive.
Tried 8 times 9th time was the Lucky one.
Pairing is still a pain (but eventually works), but yes the latest firmware seems to have fixed the problem :tada:
The sensor stops with updating the information
I am actually looking to buy more of these sensors but they seem hard to find? Anyone received any recently?
If you still have some issues on HP2023, then test latest v10.0.0-rc.66
Bluetooth LE
  • Changed the discovery interval from 10s to 5s.*
  • Improved performance when scanning for Bluetooth LE devices.*
What about Ali ?
https://www.aliexpress.com/item/1005001614827921.html?algo_exp_id=ed083d41-3ba3-4888-b058-9adc69c8611f-0&pdp_ext_f={"sku_id"%3A"12000024005627202"}&pdp_npi=3%40dis!CZK!844.31!599.51!!!!!%40210218bf16801098845191441d070e!12000024005627202!sea!CZ!139814680&curPageLogUid=ko0Sq4n7dact
Ook nog goedkoper en in nederland👍🏻
@Glenn_Seegers Bought 2 sensors here a few months ago. 1 worked first try and the other tried several times to connect but could not connect. Email sent. Defective sensor sent to the seller and a new one in the mailbox after a few days. And it did worked first try. So ordering in the Netherlands can be easy. Although it will also work out through Ali. So if a sensor does not work, it may also be defective. Although we don’t assume that.
Got the 0 measurements back on the flora max with the new update
@Koktail Since the new update, my Mi flora sensors doesn’t report any more. when I pull the battery it reports 1 times and after that not anymore.
recently I keep getting an error BLE Timeout" is this an error from the app or do I have to go to Homey for this.
I also don’t see if there is an experimental version of this app.?
I have the same problem, devices no longer report.
ea215a3b-6d65-4596-bf4d-749ce8f8d3d3
Same here no reports
