@Sharkys Yes somehow it’s not coming back. check multiple models and brands.
Thanks for the update! Range is now working with my Audi A3 Hybrid. The outside temperature sensor is still visible without a value (same as before).
@mluecke can you send a diagnostic report?
via the mobile homey app:
More - apps - myAudi - settings wheel right top - send diagnostic report
Sure - Report id: 7255e813-d1a6-4ef6-b120-8ff30863917c
New app update (test: 1.9.3)
Changelog:
- FIX: remove outdoor temperature (not supported anymore)
- FIX: range (km) update
- NEW: add latitude and longitude (if available)
- FIX: remove outdoor temp from main driver
Changelog:
Changelog:
Changelog:
- FIX: Cupra update was not working
- FIX: update issue
@mluecke should be fixed
@Espen_Botnan for the data update. Can you try to start the car and see if the data updates?
I think @peltsi51 mentioned that once for the ID3 that it goes into sleep mode sometimes.
Hi @martijnpoppen
The GTE range is still not updating for me. (Last update One month ago…)
The outside temp was nice but gone….
The other Thing I am wondering about is how I would use the longitude and latitude to calculate closer to home than the one that is calculated by the app.
(No and cards with longitude and latitude)
Thanks for the help!!
Hey @Bug
Ah i see, Fix is on the way
yeah I checked all the test cars I have and it’s completely gone. Once it comes back I’ll add it again ofcourse!
You can use the capabilities in tags. Didn’t want to add the cards yet as I haven’t found a usecase (yet).
But i’m thinking it would be nice to generate a map url so you can have a map somewhere where it shows the car position
New app update (live: 1.9.4)
Changelog:
- FIX: range (km) hybrid
Changelog:
Changelog:
Changelog:
New app update (live: 1.9.3)
- No updates
What a phenomenal job you are doing @martijnpoppen. Amazing!
Just food for future thoughts, have you thought about integrating A Better Route Planner for electric vehicles (I think Hyundai/Kia app for Homey have it). Seems that you have all you need in your app already.
With that being said, it is just bonus functionality
@martijnpoppen just send a report as 1.9.4 does not fix the Range for the Golf GTE.
And another thing, the max charge on the GTE is 16A. When set from the app it shows 16A but when set through the car (max) it shows 32A instead of the max 16A. I guess that will be different for the e-golf but the GTE (and A3 hybrid) are max 16A
+1 on that for eGolf, also sent the debug
Could be used to make a smaller circle around home although I think it would make more sense to have a advanced option for that in the app it self (on the wishlist already I believe)
That could be send to google maps for instance to show where the “should be”
Will check!
Saw your report already
Yes! Will make a option soon for that !
Yes already made a google maps url. Will attach that as a global variable
New app update (live: 1.9.5)
Changelog:
Changelog:
Changelog:
Changelog:
- No updates
@Bug should be fixed. The max charge I’ll fix begin of august. Not available for Homey next week
