Thanks Martijn. Installed and tested the experimental app, but unfortunately it appears to be not working. No data is updated.
Btw: Cupra is a separate EV brand, and is not under Seat anymore. Maybe consider to have a separate App for cupra, with the cupra logo? The Cupra I have is a Cupra Born.
@Espen_Botnan Fixed the issues and created a separate app. It’s in certification now. As soon as I have the test version available (when athom approves it ) I’ll share it with you
Thanks for making the time Martijn!
A new house always takes more time than expected.
For me (Enyaq) it works!
Drove 40 minutes. Now i can see the range/percentage go down every 5 minutes. Nice!
Not sure yet if all values work. Range and Battery tested and work.
I can test climate when going to work. Not sure about ‘outside temperature’. I think the label is incorrect, guess you meant ‘Preset Climate Temperature’. It’s exactly my set temperature
Charging can be tested tonight.
Feature requests (nice to have):
In the MySkoda app you can set:
Cable Lock (always unlock charging cable).
This would give me the option to unlock the cable instantly when at home (needs a double unlock to release) but keep it connected when away (prevents stolen charging cable).
Charging Power (Reduce current).
When charging at home I could ‘avoid’ peak hours (No app yet for Alfen Eve )
Dynamic refresh rate.
When a value changed (obviously range/battery/charging state), refresh interval 1 minute.
When nothing changed for 5 minutes, back to 5 or even 10 minutes?
Ofcourse I can create a flow for this (when someone away/home or X changed), but maybe it’s usefull for everyone.
Thanks again!
Do you have a prefered ’ donation service’?
Because of all the time you spend, I think everyone should donate for each app they use
@martijnpoppen just that this will not get lost, is the remaining climatisation time “issue” on the issue list or it’s VW issue only / eGolf issue? Thank you.
Donation send! You can buy something for your wife to thank her for your time
OK guys, everyone using this or another of Martijn’s app, send some euro’s to support his hard work!
I know how many hours could get lost in creating and maintaining an app. No better feeling than supportive and happy users
@martijnpoppen Hello! First of all, thanks again for these excellent applications, which were clearly missing on Homey! As far as the SKODA Enyaq is concerned and according to my tests yesterday and this morning, everything works (data updates) except for two points: no update of the outside temperature (well, I don’t care personally…), and impossible to start the air conditioning and set a target for the inside temperature (that would be quite practical!). Thank you very much for your work!
just sent debug - cf810210-5d81-40f2-9a48-ec76c69c7145 - last update 14 hours ago, orig. app works fine Seems caused by last update?
Correction - seems that battery level,driven mileage , km to inspection got updated 6 hours ago, which is okay BUT not range and outside temperature not (14 hours ago).
Thank you, will check (so far it’s not updating, probably it needs time) but I wonder about the outdoor temperature - this was removed by VW in the API?
