Hi Martijn.
Unfortunately the Skoda app is not working again. There was even a connection yesterday, The app cannot find the VIN (Skoda Enyaq)
Hi Martijn.
@AdrianusJ i assume you removed the car in the meantime?
Please send a report
I haven’t removed the car yet
If I choose to send report, the “send report” button remains gray
Did you fill in a message?
91bc5128-7c08-46fe-b273-45382c7de17b
I restarted the Homey app and it now works.
This is the code.
@AdrianusJ yes nothing to see now in the logs. Those are cleared after restart
That is unfortunate. I’m going to add the car again. Then I will test it again… I will keep you informed. Thanks again!
Good morning Martijn, There is no communication with the car, see this print screen. There is no response to the buttons or via a flow. I have tested this several times
@AdrianusJ please send a report. And enable debug in the device settings of the car in Homey before you do so
29a9778d-10a8-4ec6-91e3-9f83a94ec14b
@AdrianusJ looks like the rate limit again. I’ll check with the maintainer of the library. Nothing i can do
What you can do is increase the check interval to prevent this rate limit from happening
Okay, I’ll adjust the interval. Thanks for your quick response!
Hi Martijn, Unfortunately the car still does not respond to commands from Homey. I set the interval to 60 minutes. I can get information from the servers via the API helper. Would you like me to keep you informed of my findings, so that you can perhaps solve the problem? I don’t know if this makes sense to you.
@AdrianusJ no i guess we have to wait for a update from the library
Hi Martijn, after a short cooldown and not trying to as my Skoda Enyaq because the Homey app could not find my car the .5 version now can add my car again.
Lets try it again for a few days till VW/Skoda/Audi will break everything again
HI,
i connected audi q4etron and in the app desciption it shows the coming/leafing home function.
But in the flow it is not possible to choose.
Does it depend on the car?
@lakritzstange yes not available for etron. Only the older A3 etron etc
Changelog:
- FIX: updateAt card had wrong type, causing issue in Homey-Core
Changelog:
Changelog:
Changelog:
Changelog:
More - apps - AppName - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
You can install the TEST version by clicking the link above and press install
Don’t want to be part of this TEST version? Install the LIVE version →
@Sharkys fix for the Homey-core issue
