[APP][Pro] Ubiquiti UniFi Protect
Hi
can anyone help me with my new cameras? I get smart detection on my honey but not simple motions detection. Unfortunately zones don’t aktivitet by smart detection. Only my old G4 bolet trigger a motion detection but not g4 and g6 instant.
@ObelixNL
I’m not sure whether this is a known bug or a limitation, but the “A license plate has been detected…” card is generating an empty tag.
The detection itself works correctly (the license plates are successfully recognised in the mobile Protect app), and the flow is successfully triggered in Homey, as expected. However, the text tag generated by the card (“License plate” tag) is empty, with no text populated.
I’ve tested this using a very simple flow, as shown below, but all I get is an empty message. Any ideas why the tag is just an empty string?
Thanks!
Hi, and apologies if this has already been raised.
I’m on the test version of the app, with a UDM SE (Network 10.6.109), a G6 doorbell and Homey Pro. Homey is on its own IoT VLAN, and I only allow it to reach the UDM on the ports below, so I can control which stream the app can use.
With only TCP 7441 open from Homey to the UDM, the camera plays in the Homey iOS app, but the Homey web app (my.homey.app) says “Camera is unavailable”.
With TCP 7441 and 7447 both open, the web app plays the camera, but the iOS app shows a black screen.
The app seems to use the 7447 stream whenever it can reach it, and the iOS app can’t play that one. Is that expected? Is there a setting to force one stream type, or is this a known issue? Happy to provide logs.
Thanks!
Dear @ObelixNL
Is it possible to integrate indoor intercom handler called “Viewer”? It would be handy to adjust Volume to certain scenarios.
Big thanks for your efforts on this and other apps!!! :clap::clap::clap:
Check this:
Can you send me an DM with more information and screenshots?
@ObelixNL
Just following up on this… For some reason the push notifications have completely stopped as if the flow is not triggering at all (flow from my previous post). Checking the Android Protect app, the cars and plates are detected there with no issues.
Hello Fac3 Thanks,
What device are you using? what is the type?
Do you use the V2 API token?
I’m using V1 in your app. I’m on Protect version 7.3.74
This one: Access Intercom Viewer - Ubiquiti Store Europe
I have fix this problemen with this
Form a user replay it above
Have you enabled Super Encoding in the latest Protect release? I had also black live screens with this setting on.
I change the setting room enhantes to standerd
Yes, I figured that one out. Protect turned on “super encoding” without asking, so it took me a bit to figure out why I suddenly started getting a black video stream in Homey. Thanks anyway!
The notifications are coming through again, although I can’t see that your app has been updated, so I’m not sure what’s changed. However, they’re still appearing as empty messages, with no plate numbers included.
Hi @ObelixNL,
Since my NVR moved to Protect 7.4.96 (Early Access channel, UNVR Enterprise, UniFi OS 6.1.4), the app can no longer control my 5 UP FloodLights, and nothing comes in from Protect any more.
App: 1.13.2, then test 1.13.7 – same result. Homey Pro (2023).
Symptoms:
  • Turning a floodlight on/off fails with: “Error setting isLightOn: Error: Homey user has no permission to perform this action. Please check the user’s role.”
  • Before I added a V2 API key, the error was “Missing Capability Listener: onoff”.
  • App settings > Status: Protect V1 = Connected, but real-time status = “Unknown” (last update empty). V2 API key = Connected. Access = Connected.
  • No motion / smart detection events have reached Homey since Nov 10 (evening); device states are frozen.
Checked:
  • The local user “homey” is a local Admin with full privileges (unchanged, worked until Nov 10).
  • App restart, Homey restart, test version 1.13.7: no change.
  • The Protect Integration API with the same API key works: PATCH /v1/lights/{id} with isLightForceEnabled switches the floodlights fine (I use this as a workaround from HomeyScript).
It looks like the V1 real-time connection / bootstrap fails on Protect 7.4.x, so the app has no permissions for the user. Could light control (and events) go through the V2 API key when it is configured? Happy to send a diagnostic report or test a build.
Thanks!
