Doesn’t make a difference but I think it stays on the high res stream, rebooting the app re-enables all 3 options so I can’t turn it off and force it to reconnect.
Hi! I found a small bug and opened a PR for it: a guest leaving the Wi-Fi is not seen, because the console reports it as EVT_WG_Disconnected and the app only listens to EVT_WU_*:
steffjenl/com-homey-unifinetwork#28 · Handle wireless guest events…. I also opened a feature request for “first / last client on a Wi-Fi network” with an SSID argument: steffjenl/com-homey-unifinetwork#29. I have both running in a small add-on app and am happy to help get them into this app.
This issue is not representable by a flow. As you can see on the screenshots above, if in a zone there are only cameras, Homey does not handle them as motion sensor, so zone activity cards does not work. While, if I put a motion sensor into the zone, Homey handles motion sensor and camera in the Zone Activity.
I noticed that the app served me low quality camera snapshots. I have some scenarios where this becomes an issue, one of them being when casting the image to a high resolution device. I’ve created a PR to fix this and would appreciate it if you could take a look.
I created one more PR. When a flow uses the camera image in more than one card, each card gets a different picture, because a new snapshot is taken every time. So I added a doorbell card that takes one snapshot and keeps it as a tag for a while, so every card in the flow uses the same picture.
Symptoms: snapshot works, motion detection works, camera is online in Protect with live video working fine there. In Homey (web app via my.homey.app) the live view never loads — it briefly shows “Stream laden…” then falls back to the last snapshot with “Camera is not available”.
What I tried, no change in any case:
Videocodec setting: Automatisch vs H.264 (forced)
Enabled Medium + Low Resolution RTSPS in UniFi Protect in addition to the existing High Resolution stream
Extra data point: I also have a G3 Bullet camera, and that one currently shows the exact same “camera not available” error in Homey — unlike what @Fac3 reported (G3/4/5 working). Happy to provide more logs/info if useful.
I finally installed my G6 Pro Entry that’s been sitting in a box for over a month, and I’m having “same but different” issues when using 1.13.2 version of the app.
When viewed in Homey web browser UI, it all works fine in best quality, I can see the live view by clicking on the device.
The story changes when using the Homey app. On iPad Mini 6, Galaxy Tab S9+, Pixel 7, Pixel 10 and few other tablets, it’s just a black screen with “live” on it, but no actual video stream. If I open Homey in a web browser (not the Homey app) on these devices, the video works fine. It’s just the Homey app that is showing “black video”.
