[APP][Pro] Ubiquiti UniFi Protect
PM sent
@ObelixNL When My UniFi Protect camera (G5 Turret Ultra) detects a person, a vehicle or an animal, it leads to a clear notification through the UniFi Protect app on my phone. (it regocognizes the right object).
But when I use the triggers in a flow on my homey (with the Homey UniFi Protect app), all triggers (vehicle/person/animal), it always leads to a Homey notification “animal detected”. Somehow the Homey Protect app does not translate the soource Protect trigger to a Homey protect trigger.
How can I fix this?
I fixed it with a workaround! You can use a webhook. In the protect app under alarms you can make a new alarm that get a Webhook. In the homey flow you can start with a logic card webhook event.
For those people who use webhooks to trigger security based flows please do this wisely. Even local webhook is open for whole local network so is highly insecure! @ObelixNL can U fix those missing cards for locks?
Its working on my configuration without webhooks, its all secure and internal. I have looked up with some people and its almost there configuration fault. They can buy personal support with me.
I using Unifi NVR Instant with latest stable version in combination with Nuki (Matter). I don’t use any webhooks and NFC/Fingerprint is working and also Doorbell ring.
Your Homey must on the same network as your unifi controller, don’t use VLAN’s when you are not a network administrator. Don’t use multple routers or public IP/hostnames and use a local account with rights.
Check the settings page, you see a status page and for NFC/Fingerprint and Doorbell websocket must be connected.
We did many installations en they still work today.
The websocket message does not sent any usefull information, I will look in the next weeks if the V2 websocket does sent more information about faces / names.
Ok so what card are u using for a trigger? Previously I used “When lock unlocked” and works. Now card is missing. I can open door via homey but I don’t see trigger card. Im using G3 Access reader and use Face as unlock.
–> This is correct! Ok all works! Ty!!!
I recently started using Homey Pro. Is it correct that my protect camera streams cannot be viewed externally via the Homey app? The streams work fine within my local network, but when I’m outside my home network I only get a black screen with a loading spinner.
First of all: Thanks for the app - i like it.
I have some questions:
  • Access Flex Reader only work, when a camera is connected, is that correct? Tested the „door access event“ and it worked only, when i connected a camera to the reader. is there a chance without camera?
  • => additional question for that “door access event” is only an positive event? it doesn’t start with false credentials, right?
  • i tested the „keep door open for x minutes“, but it seems not to work. It openes the door (and keep it open), but after the 1/5 minutes, it still stays open, until i say „lock“. (i‘m using Flex Reader, Door Hub Mini and magnetic lock for that)
Would be happy for a short reply.
please,one question i have 2 g5 cameras are allowed to work with snapshots on homey flows? @ObelixNL
how do you run successfully snapshots or live stream from G5 torre cameras?
No one who has an answer to this?
The homey grabs the local rtsp stream from your NVR but does not forward this to the homey cloud. Therefore it just works locally. UniFi protect uses their cloud to restream the cameras to your device when you are off the network.
The integration with the UDM on a Homey Pro 2019 gives me a certificate issue, as the certificate on the UDM is only valid for “unifi.local”. Using the Unifi Ubiquiti Protect app with the IP address will give a failure on taking a snapshot. Having added “unifi.local” as a DNS-entry on the UDM does not solve the issue, as using this address fails when configuring the Protect app (credentials are invalid when testing). How to solve this?
Would it be possible to add the option to use a domain name instead of an IP address? That would require DNS resolution, but should not be too hard, I’d say.
I can’t add any cameras. Installed app, configured user/password, Test worked fine but trying to add a new camera device, just spins away forever.
Did you manage to figure this out?
Seems like home assistant have a work around for this: Expose face recognition from Unifi Protect integration - Feature Requests - Home Assistant Community
I have a NVR Pro connected, the Snapshot Feature works but the Live Video Feed does not work. Is this due to the fact that Homey might not support RTSPS Streams? I have the same issue on another location with Homey Pro connected, to a UDM Pro.
Anyone noticed UniFi Protect video feed stopped working with either latest IOS or Android 9.7.1 with Homey Mobile App? It appears to play audio, just black screen for video. Either Homey Dashboard or via Device object.
Note : UniFi Homey app is successfully connecting via v1 & v2 authentication.
Running latest UniFi software and camera firmware.
9.7.1 included “Improved WebRTC error handling to prevent unnecessary fallbacks and increase camera stability.” Which raised my eyebrows.
