V2.3.10 is not connecting to Unifi anymore
c4ea2855-f08f-456c-8efe-ccab693d3dc4
Anyone encountering the same?
Yes, the same here.
Had same issue. I went to the Unifi app on my homey. Then clicked on restart app. After that it was connected again and all devices linked to Unify showed up without problems.
Restarted many times doesn’t work Unifi 3.2.5 or Network 8.0.2
Make sure to use the Ubiquitu Unifi Network app from Stephan Eizinga. I have the experimental version v.2.4.0. And all is working now.
Yeah obviously I’m using that app lmao but as said I’m on the latest public version and it isn’t working
How did you get the experimental version?
Did that help you?
After I no longer had any connection with the default version 2.3 (even after a reboot). Checked if the test version 2.4 works. In the configuration the values are filled in again: local ip adress ,etc. (password 16 characters) and when testing the credentials I get the message that they are invalid (local logging in to the UDMPRO with the credentials works just fine). If I change the local ip address to the external ip address, my credentials are fine. With both options, when adding devices I get the following error message ‘response.filter is not a function’.
I hope you can help me
Hello Sweetlake, I think I can not help you with that specific issue. Maybe someone else who is reading this and also uses an UDMPRO.
I don’t use a dreammachine, because they often cause problems.
My controller runs on my own server, so that’s another route. Only thing I can suggest (if you did not already try) is to manually stop your controller. Shut of the UDMPRO with a powercycle (15m). Also shut homey app, restart phone. And after 20 minutes try again. Hope this can be of use. Good luck!
Nope doesn’t work, same issue as Sweetlake
Then same advice to you. Or maybe contact Stephan (@ObelixNL) for advice.
Power cycling doesn’t help, probable that Ubiquity changed something on its UDMs…
Do you using an local account with admin rights? Are you using an controller (UDM or Cloudkey) or hosting your own unifi network app?
What network version are you using? Still 8.0.2? Latest version what i can test is 7.5.187-ls13
I use a local account with super admin rights and use the local console/controller (no cloudkey). It has always worked for 3 years with the UDMPRO and since a few days it does not work anymore.
I hope you can help me investigate further.
Thanx for your reply
Unfortunately no result
What is your network version? Do you have Slack or WhatsApp?
Version 8.0.2. Slack invite is send
I’ve got the same issue with Unifios 3.2.5 and network 8.0.2. Did you already find a solution?
