If you can also make the names of these data fields (organic, residual, paper etc) manually editable it can be used in any language.
The names in the global labels are already dynamically editable through the settings page. But I guess you mean to make the names dynamic in the widgets?
Yes
So today a completely rebuild version is rolling out to the test users. For others interested, you can install the new beta version here: Trashcan Reminder 2.0 | Homey.
Please note that the app is completely rebuild, so that this new beta version might be less stable.
Next to the complete rebuild, there are also some new features available in this test version:
@Victor_Bicknese, @johan_W; Uithoorn and oude IJsselstreek are now supported
@Alex_Wijnsma; Noardeast Fryslan should be working again
@Bkinsbergen; The dashboard should now refresh on a daily basis
@Paal_Aamaas; On the settings page you can customize the trash icon, color and label for your widget
If you have any findings, either send me a PM or create a bug on GitHub.
Any general remarks can be posted here in this thread as well.
Hi Robert, thank you for all the good work. And very vast, awesome.
I installed the test version and I go this error: Cannot read properties of undefined (reading ‘GFT’)
I Made this diagnostic report, I hope it is helpful: 8e0bcaf4-7f0e-494d-a9b9-767b458647af
Met vriendelijke groet,
Victor Bicknese.
You can do that now through the app settings page (instead of only in the widget). There you can select “N/A” (not applicable) if you don’t want to see it in the dashboard. This way it will directly also be removed from notifications through flow.
I saw the diagnostics report, but as usual, it doesn’t make it any clearer. Do you have a screenshot of where you see this error?
Thanks I Found it. But I still have the space between the two containers. But I think this is the way the widget is build.
Hallo Robert (ik schat je in als Nederlander, maakt de communicatie iets directer),
Jammer dat de diagnostische rapporten onvoldoende info geven!
Het is vandaag GFT dag bij ons.
Deze melding krijg ik bij het uitvragen of er vandaag iets wordt opgehaald.:
Dit zijn mijn settings:
Overigens ziet de Widget er wel prima uit. Er is dus iets in de flowcard lijkt me (maar wie ben ik…).
Heb je hier voldoende aan?
Groet,
Victor.
Thanks, haven’t done a regression test on the flow cards to be honest. Too bad that there seems to be something wrong with those. It was the only part that didn’t change much
. Will try to have a look soon!
And yes, Dutch, but some rule on the forum indicates that we should communicate in English except for the Dutch part on the forum ![]()
Sorry, in English next time. Appreciate your work!
Yes, with only two pick-up dates it is best to set the layout setting to compact. And if you only have two dates set the row/line-height to 1.
Thanks. I over looked this possibility. Now it is ok. ![]()
Just published a new version to the test channel that should have a fix for this flowcard issue ![]()
Thank you! 'm not able to test it right now, first pick-up day is next Monday.
But I’ll let you know. Thanks!!
I tried to remove organic as it is collected every week anyway, and I had to manually restart the trashcan app to update it.
