One small gamechanger idea:
In the settings after integration this field is not editable. Can you make this field editable? (for changing url to https or portchange or whatever.).
You can override it in the User URL field below it. If that field is empty it uses the data received from the camera, else it will use the user input.
It doesnât work properly with my Anke Cams (HikVision Label), if I want to send a snapshot, it takes forever or the app always crashes.
c0112a76-d8cc-4dba-b6b9-e9dddefdd02b
Hi Adrian,
The onvif experimental versions work for my mobotix cameraâs. Unfortunately the official version of the app doesnât.
For some reason when refreshing the snapshot or movement, the snapshot or movement image which is send via a flow to my telegram account after refresh is still tje old image when the onvif app was first activated but not the latest.
I send you a log. Any idea what is going wrong?
The log shows everything is working as expected.
Does the image in the Homey device update OK?
Could you show the flow you are using?
The log has lots of errors:
2023-11-04T07:12:27.643Z [log] [MyApp] SnapShot error (Cam Garten): request to http://192.168.178.89/onvif-http/snapshot?Profile_1 failed, reason: socket hang up
socket hang up means the camera is not responding to the request. could you try putting that URL into a web browser to see if you see an image?
Please see the flow in Dutch language.
The snapshot updates fine when looking im the onvif app. Itâs when i try to send the snapshot via telegram, then it is sending the first old snapshot. Is there a way to check what snapshot image homey is seeing/storing.
I canât see what triggers the Flow, but I see you then update the snapshot. That takes a bit of time so the following commands probably run before it has fetched it
There are two solutions:
With the URL directly from the camera, I can see the screenshot without any problems
That is strange. Have you tried rebooting Homey to see if that helps?
The other issue I see in the log is a lot of storage failed events coming from the camera,. However, the camera hasnât reported that it supports those events, so the alarm capabilities wasnât created. That appears to be the cause of the crash as it makes the app uses too much CPU time.
I have made a fix that I will publish that partially overcomes that by adding the capability on the fly so it no longer reports an error but if the events keep hitting the app at the current rate it might still crash it.
Well, in fact I just test again andâŠit works! I dont know if itâs related to your last update or notâŠ
Best,
JĂ©rĂŽme
Hi everyone,
I am trying to get the sabotage event triggered. What can I do?
I have a reolink poe doorbell and when I open it and/or remove the lan cable it does not fire any event. Motion and Visitor events are send.
Does anybody have an idea how to fix this?
AFAIK the doorbell doesnât have any tamper detection.
Also, how would the camera be able to fire an event when you remote the LAN cable, which also provides it with power?
Thanks for the reply. I was hoping that it somehow detects the opening of the case.
Doesnât look like it, my WiFi Doorbell doesnât emit anything when I pop it from the holder.
Question; sometimes the âpersonâ card disappears for one of the cameras, is there some logic to this?
Also, would it be possible to have a smart detection card like the ubiquiti system I have?
This would make for a âcleanerâ flow in my case.
Some of the capabilities are added on the fly base on the information that is received. I will take a look to see why it disappears.
What do you mean by a smart detection card?
Thanks, tried restarting the apps and homey but that does not cure it.
It has disappeared before but after a while it came back in the list. just strange that it happens for the one camera, and there is 2 identical ones running on a nvr (channel 1 and 2).
The ubiquiti app has a card for smart detection, if it is a vehicle or person identified by either of the cameras (not including motion alarms which I donât want, and ubiquiti does not support pet detection sadly.) it will activate.
If the onvif app had a similiar card one could add events like vehicle/pet/person/visitor with one card for several cameras?
So the person alarm is removed if the camera does not report it supports that option:
if (notificationTypes.indexOf('PERSON') >= 0)
if (!this.hasCapability('alarm_person'))
this.addCapability('alarm_person')
.then(() =>
this.setCapabilityValue('alarm_person', false).catch(this.error);
.catch(this.error);
else
if (this.hasCapability('alarm_person'))
this.removeCapability('alarm_person').catch(this.error);
I will look into adding an app based trigger for motion that has a tag for the type of motion that was detected.
