In the Homey mobile app you can choose which property to show for a device. Click cogwheel of device to go to advanced settings and then click status indicator. This takes you to a list of properties you can choose from.
This seems to not exist for the Homey web app (yet).
Someone correct me if Iâm wrong, but my understanding is that HM2 needs to be connected to the network (switch) and not directly to the inverter, for the UDP multicast datagrams to be published to the network. Ie wont work when connected to the inverter.
could you please add the manual ip address field into the âenergy meterâ device? because in different vlans there is no chance to find the device anymore
Replied to your email. Unfortunately not much in the diag report (as usual).
I just issued a new release where I have tried to remove most local variables from the code since I have observed in another app I have that these can be wiped if the app is running for a long time.
Keep me updated on the new version.
I think it is not your app, but the sma device, I cannot reach it anymore via IP adres or your app⌠Afraid I have to borrow someoneâs bill gates laptop, install sma Explorer, reset and connect⌠Bummer, thanks for looking into this
Seems that since last update, upload to PVOutput.org is not complete anymore.
Power is updated, but Energy, Efficiency, etc. is missing.
See screenshots:
I have a issue that my solar inverter SUNNY BOY 4.0 and my SMA Wallbox EV Charger 7.4 wonât be identified? But the SHM2.0 ist identified without problems.
Modbus is activated and also Port 502 selected
Did someone having some ideas?
No support added as of yet for it. Maybe a good project to try and add that. Will need one or two guinea pigs for trying this out given that I donât own one myself. Ideally, someone that is able to install the app via CLI so we more easily can capture logs. Volunters?
As for SUNNY BOY 4.0 Iâm note sure what the problem is. It is not auto detected, but you can add it manually using the IP of the inverter?
I donât know what is going wrong with SB 4.0.
Autoidentify dont works. After adding IP manual the device Name appears, which can be selected. The dialog has only one button with close. At the device overview only power drawn shows data. Adding just work when using âsunny Boy storageâ Not inverter
This guide is pretty good for understanding how to install an app via CLI - feels like we need it for the SB inverter issue, since I canât see anything obviously wrong, it should be supported.
âCould you please add the manual ip address field into the âenergy meterâ device? because in different vlans there is no chance to find the device anymore â
Same problem here. Is it possible to add manual up Adresse for energy meter?
Sunny Boy storage should only be used for hybrid inverters with battery option/connected. For plain solar inverters you need to use the inverter device type.
As per instructions above
enable modbus, it is disabled by default.
If auto discovery doesnât work then your network doesnât allow UDP multicast. Then you need to manually add it using ip of inverter.
If you have tripple checked the above then let me know inverter model, ie exact model name and I will have a look. This week Im off though.
I am trying to add my SMA inverter to Homey. The app finds the inverter, but does not add it. Instead of adding it says âcloseâ in the process. Does anyone have an idea how to solve this?
