I found the problem. Thanks for your feedback. Api response changed and i updated the app to reflect those changes.
Basically the app was not able to understand car position and for this reason “Car is at home” was never updated. Now it should work.
Can you please update test version with the new one (same url) and try back again?
Hi, I just started using this app. It works (only not with the location showing as “Home”) for displaying all settings.
Now I want to stop the car charging when it reaches 90%, but when I activate the stop charging option in a flow I receive the following message:
Is it possible to limit how often this app calls the Renault API or does somebody know how to create an extra (for example Homey) user at Renault for the same car?
Sometimes when I use the Renault app itself, data won’t be displayed as if I was making too much requests.
So for example I couldn’t pre-heat the car, after disabling the Homey app, I could pre-heat it again.
Dacia app on my smart phone works fine, home assistant with Dacia integration works fine. I use home assistant with homey for Dacia automations for now. Would really like to use a direct Dacia Homey app, but it doesn’t work anymore.
