[APP][Pro] Powerview- Luxaflex & Hunter Douglas
@Erik_Rutten yeah was afraid so
Unfortunately the log is cut off so it don’t see the data from “wk links voor”
Can you try a force update of the data via the button on the hub and then send a new report ?
Done
983da78d-2a91-46c2-a9f8-73f9b44e7b45
Rgds
Erik
Verzonden vanaf mijn Galaxy
-------- Oorspronkelijk bericht --------
@Erik_Rutten I don’t see any difference unfortunately. (log is capped off again).
can you make some changes to the shades and then send a new report?
72d16e3c-949f-4ef5-819c-dc1a1816b8df
Rgds,
Erik
@Erik_Rutten so the data in the report looks correct
WK achter rechts: ‘tilt: 0.7, primary: 0.11’
Step 1: Hight to 20% (position 2)
Step 2: Tilt to 40% (position 1)
622ff6e7-4712-4a81-bef3-04c47a4848df
Tilt position initially correct displayed in Homey
After pushing: Bijwerken raambekleding (no other changes)
461abd66-7d1a-42a1-95cf-4f54e943910c
Tilt position not correctly displayed
@Erik_Rutten thanks! I need some time to dive into this. Will come back on it tomorrow
New app update (:green_square: LIVE: 2.10.7):
Changelog:
NEW:
1: None
FIXES:
1: FIX: timing issue with updating shades
More - apps - Powerview - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
@Erik_Rutten I made a new update. Can you check if this resolves it? :slight_smile:
Hi Martijn, it looks Ok now. Many thanks for fixing this :grinning_face:. Rgds, Erik
@Erik_Rutten Great to hear! :raising_hands:
Hey Martijn,
Got a problem.
I removed the devices because of IP-problems. Now the app seems to think they’re still here because when I want to add them again, the app says “no new devices found”.
I removed the hub in the app, din’t help, I restarted the app didn’t help, I removed the app and re-installed it. Didn’t help.
Maybe you can have a look? Tia.
Key: 3f577460-7973-4a6c-b0f3-07cbf83fff85
@Scoovey this IP is not correct for your PowerView hub
Make sure to set the correc IP
http://192.168.178.31/home/shades
Gets me everytime, the **** IP-address.
Changing it didn’t work though, still can’t add my raamdecoratie devices.
7b3a009f-3ca0-4897-9ded-a29524ff871e
@Scoovey still not reachable
Also still the same
That’s weird.
The Powerview app says: 192.168.178.29. So does the Homey app for the hub.
And when I go to http://192.168.178.29/home/shades I see this:
(http://192.168.178.31/home/shades gives an error)
@Scoovey try to restart the app maybe?
Allready tried. Even de-installed the app and reinstalled it.
But will try it again.
Maybe I should change the IP address to 192.168.178.31 everywhere?
@Scoovey most of the time if you change the IP on your PowerView hub you have to restart the hub to have effect
