@Peter_Raijer please send a diagnostic report
Ha Martijn,
I’ve got the same problem as @Peter_Raijer.
What can I do to solve the problem?
Grtz.
Linda
@Scoovey this is a English topic
Please edit your post and translate it
Thanks
Done
@Scoovey Thanks
Please send a diagnostic report
@Scoovey the ip address of your hub changed. So make sure to set the correct IP in the settings of the PowerView hub in homey
However if you restart the PowerView app in homey it should also try to find the correct IP
Thanks!
Restarting didn’t help, but correcting the IP did.
New app update (
LIVE: 2.10.5):
Changelog:
NEW:
1: NoneFIXES:
1: FIX: wrong position when motor settings are changed
More - apps - Powerview - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
@Erik_Rutten can you check the above release and see if it resolves your issue?
I couldn’t reproduce the issue with a Duette motor. Unfortuantely i don’t have any tilting motors to test with. Let’s hope this works.
Next to that I added a lot of extra logging so if you send a new report I should get a bit more info if it goes wrong.
Martijn, thanks for looking into this. I installed the new version. Unfortunately I now get the error: oldValue is not defined.
48d53bfa-58a6-4c5a-8d2f-a959faf7ae7d
@Erik_Rutten thanks will have a look!
If it helps: same error only on Duettes. Diagnostic code: c2443cbb-3b72-4c05-bf91-b62c1ca06a37
Appeared with the new version release. First position 2 setting works, but blocks with “oldvalue not defined” right after that.
@Dominique Yeah will check
New app update (
LIVE: 2.10.6):
Changelog:
NEW:
1: NoneFIXES:
1: FIX: error
Just installed, error gone.
Crazy fast, thanks so much! ![]()
Hi Martijn,
The error is gone.
The display of position 1 (tilt) still shows the wrong numbers after executing bijwerken raambekleding.
I will check more in detail this weekend.
Rgds,
Erik
Verzonden vanaf mijn Galaxy
-------- Oorspronkelijk bericht --------
@Erik_Rutten thanks!
Please send a report when possible
Hi Martijn,
Still the same issue.
2c377839-6d02-47d3-b504-1f609ffd4a28
Rgds,
Erik
