[APP][Pro] Powerview- Luxaflex & Hunter Douglas
New app update (:green_square: LIVE: 2.10.4):
Changelog:
NEW:
1: None
FIXES:
1: FIX: round position to 2 decimals
2: FIX: error in powerview hub due to typo
More - apps - Powerview - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
@Koen_Crijns this is a english topic. please remove or translate your post.
Fix is already implemented
@martijnpoppen I have set the screens to a different position, restarted the app and it showed the new position 54%. But when I set the screens back to the previous position, I again see 56.0000000000001%
@Jos_Stultjens can you send a diagnostic report?
Hi Martijn,
I have sent the diagnostic report:
d0bd601b-d4a9-41eb-9358-f9992364c5e5
@Jos_Stultjens please send the report after you changed the value, currently i don’t see any of that
Hi Martijn,
I have set the screens to a new location and updated the value. Next I set the screens to the previous position and again updated the value.
This is tge new dagnostic report:
1928782f-da20-4e93-bd07-22bb622e2b0f
@Jos_Stultjens Just checking everything, but how did you get those percentages on the device tile in the first place? that shouldnt be available sensor
Edit: wow there’se a difference between webapp and mobile app in the optins. Reported that to athom.
Next to that will check if i can even influence this as this is default homey cards which im using for this
@martijnpoppen : Indeed, in the webapp you only can select the battery status, or "“None”.
In the Mobile app (iPhone), I also can select “Positie 1”.
In the device tile it is not formatted nicely(rounded), but in the status indicator field it is formatted.
But there it shows as 0.56% instead of 56%. This also seems not to be correct.
@Jos_Stultjens interesting sounds more like a homey bug than something I can do
But I come back on this
after the automatic powerview update 2.10.3 last night the contact with the powerview hub is broken.
Restarting of the Homey, Powerview and the router doesn’t fix the problem.
@Edgar_Markovic a fix was already made last evening [APP][Pro] Powerview- Luxaflex & Hunter Douglas - #366 by martijnpoppen
Make sure to update the app
@martijnpoppen i saw that in this app there is sometimes a percentage of about a lot of numbers after the comma.
I have a Aqara humidity sensor thas has the same issue.
Maybe it is a Homey thing?
@Mike1233 yes it is. Already send it to athom :slight_smile:
See: [APP][Pro] Powerview- Luxaflex & Hunter Douglas - #374 by Jos_Stultjens
Hi does this app work with vertical blinds? I added the gen 3 hub but can’t seem to find my vertical blinds.
thx
Hey @Har_Dou
Yes it does
Are homey and PowerView in the same network?
Hi I’ve added a screenshot from what I get.
@Har_Dou did you try to add the window coverings already? Looks like you only have the hub
There must be something wrong with my hub because it asks me an ip adress when I want to add my window coverings. I’ll check that out.
Edit: reset my hub and everything is fine now
Hi Martijn, the position indicators show the wrong percentage. After restarting the Powerview app the position indicators are ok, but after executing: “bijwerken raambekleding” they change in 0%, the wrong percentage.
