Furthermore, it would be nice when I could also choose position 2 as the default view in the tile: status indicator: Position 1, Position 2 or None and in the app => showing the wheel of position 2 when opening the app,
@Erik_Rutten Can you send a report for that error?
I understand what you ask, but unfortunately i have no control over that, this is how Homey does it.
What you could do is set motor 1 to tilt and motor 2 to primary. then you achieve the same goal ![]()
8e18f00e-51bd-4218-a69c-87b0c9c0fade
Verzonden vanaf mijn Galaxy
-------- Oorspronkelijk bericht --------
Yes, that was also my thinking
. The visualisation (position 1: high low visual versus position 2: tilt visual), but I will get used to it.
Thx
Rgds,
Erik
@martijnpoppen I just installed the test version of the app and also restarted it. (And I changed the IP address to a fixed one now). This gives me new issues.
As you know I have eight shades. About half of them see the new IP address (…78), but the other half still uses the old IP (…249). Restarting the app does not change anything. And doing another new search on shades give me the exact same issue as before…. No shades are being found (while the IP address of the main hub is now correct).
And I also have the problem that eric describes. It gives an error about position 1 when I want to open or close a shade (and that shade is using the correct IP address). The tilt function however is working correctly on that shade now.
Here is the diagnostic.
f61acb0d-5305-48ec-a1f3-68a78e396d8a
Hi Martijn, I now use position 1 for the tilt action and position 2 for the high low action. The error remains with position 1.
New app update (
TEST: 2.10.1):
Changelog:
NEW:
1: NEW: add motor settings for Gen 3. This allows the user to override the slider to a different motorFIXES:
1: FIX: error in device settings
2:* FIX: shades not properly updating to hub IP
More - apps - Powerview - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
See the update above ![]()
Shade IP’s will be update on start of the app so they are in sync with the hub
and the issue on the first slider is fixed
Hi Martijn, it is working fine now, thanks. Only one strange thing now. Pushing: " raambekleding bijwerken" triggers an error: Missing Capability Listener: update_data. By the way, what’s the functionality of this button?
@Erik_Rutten you can disable the update interval and do manual updates. If you for example don’t want to ping the hub all the time. Was a requested feature in the past
I’ll check that error
@Erik_Rutten I checked that error, but i think it was a timings issue. Can’t really find a bug for that. can you retry that button?
Hi Martijn, pushing the button still generates an error, but the red error box disappears that fast that I can’t read it. Pushing the button doesn’t result in the button toggling between on and off. Doing the same via a flow every 15 minutes seems to work ok.
Hey
Wil test with gen 3 as well
Coming back on that
@Jos_Stultjens Oh nice feature ![]()
i can change that. Will round it to 2 decimals
Thank you
New app update (
TEST: 2.10.2):
Changelog:
NEW:
1: NoneFIXES:
1: FIX: round position to 2 decimals
@Jos_Stultjens can you install the test version by clicking the version number in the post above. press the green install button on the app page and see if this works?
Hi Martijn,
I installed version 2.10.2, but I still see 56.00000000000001 %
I also after update restarted the app once more, but no change in displaying the value.
@Jos_Stultjens can you make sure to set the position to a different number and then back to this? It’s only on update ![]()
