MyParcel for Homey
Track your parcels from multiple carriers directly in Homey with a single app.
MyParcel for Homey brings supported parcel carriers together in one place, so you no longer need a separate Homey app for every delivery service. Add the carrier devices you use and keep track of incoming — and where supported, sent — parcels directly from Homey.
Depending on the carrier, MyParcel connects with just a tracking number, or with your personal carrier account using the carrier’s available interfaces. Some integrations may use non-public interfaces and may therefore require updates when a carrier changes its mobile app, website, API, or sign-in procedure.
MyParcel is the name of this Homey app and is not affiliated with or connected to MyParcel.nl.
Available in 13 languages: English, Nederlands, Deutsch, Français, Italiano, Svenska, Norsk, Español, Dansk, Русский, Polski, 한국어 and العربية — devices, Flow cards, tokens, pairing screens, widgets and notifications.
Supported carriers (19)
| Carrier | Countries | Connect with |
| PostNL | Account (e-mail + password) | |
| DHL | Account or tracking number | |
| DHL Express | Air waybill number, optional MyDHL+ account | |
| Post & DHL Germany | Post & DHL app login or DHL.de login | |
| DPD | Account | |
| GLS | Tracking number + postal code | |
| UPS | Account (Login Helper) or tracking number | |
| FedEx | Your own FedEx API key | |
| Budbee | Tracking code | |
| Vinted Go (formerly Homerr) | Account (e-mail + code) | |
| InPost | Tracking number, optional account (PL/IT) | |
| bpost | My bpost account or barcode + postal code | |
| Royal Mail | Click & Drop API key | |
| Ampère (bol.com) | bol.com account (Login Helper) or the link from the bol.com e-mail | |
| Trunkrs |
| Dynalogic |
Order number + postal code | |
| Dragonfly / Intelcom |
Tracking number | |
| Mondial Relay |
Mondial Relay / InPost account | |
| Amazon |
17 stores: |
Sign in on Amazon’s own page |
More carriers may be added in future versions.
Each carrier has its own device and connection, so you only use the delivery services you actually need.
Linking a carrier
- In Homey, go to Add Device → MyParcel.
- Select the carrier you want to add.
- Follow the instructions shown during pairing.
Tracking number carriers
DHL, DHL Express, GLS, Budbee, InPost, bpost, UPS, Trunkrs, Dynalogic and Dragonfly / Intelcom work with just the tracking number (for GLS, Trunkrs and Dynalogic together with the postal code of the delivery address). You can add numbers while pairing, in the device settings, or with a Flow (Track parcel). Add “out” after a number for a parcel you send yourself where the carrier supports it.
PostNL
PostNL no longer needs a helper: sign in directly in the pairing screen with the e-mail address and password you use on jouw.postnl.nl. Your password is only used to sign in; Homey then keeps the PostNL login tokens, not your password.
UPS and Ampère (bol.com)
These use a Homey Login Helper for Google Chrome:
- Download the appropriate helper:
- Extract the downloaded ZIP file.
- Open
chrome://extensionsin Google Chrome, enable Developer mode, and select Load unpacked. Select the extracted helper folder. - UPS: sign in to UPS in Chrome, open the UPS dashboard and wait until the helper reports that the web session is ready. Ampère: sign in once at login.bol.com.
- Copy the value the helper shows (UPS login data or bol.com session code).
- Return to Homey, start pairing the UPS or Ampère device, paste the value and complete the connection.
For UPS you can also add tracking numbers without an account, and for Ampère you can paste the tracking link from the bol.com e-mail instead. With the bol.com session code, MyParcel finds your Ampère deliveries automatically.
DHL Express
DHL Express works with just the 10-digit air waybill number. Optionally add your MyDHL+ account; if DHL asks for an interactive check, the pairing screen explains how to use the DHL Express Homey Login Helper.
Mondial Relay, Amazon, Post & DHL Germany and InPost account
These carriers use their own sign-in page:
- Choose your country, Amazon store or login type and open the sign-in page from the pairing screen.
- Sign in as usual (password, SMS/verification code, puzzle or passkey all stay at the carrier).
- Copy the full address of the page you end on and paste it into the pairing screen. The page may look blank or show an error — that is expected.
Each sign-in link works only once; if something goes wrong, the pairing screen gives you a new link. Mondial Relay requires that your account has signed in once on the Mondial Relay website or app.
Other carriers
For the other carriers (DHL, DPD, Vinted Go, bpost, FedEx and Royal Mail), follow the instructions in the pairing screen and use the same account or e-mail address that you normally use in the carrier’s official app or website. Some carriers may require additional authentication steps; the pairing screen guides you through them.
Privacy & security: Wherever the carrier allows it, MyParcel keeps login tokens instead of your password (for example PostNL, bpost, Mondial Relay and Amazon never keep it). Never share authentication callbacks, sign-in addresses, session tokens, access tokens or other login credentials with anyone.
Parcel information
MyParcel retrieves updated shipment information from your connected carriers: every 15 minutes when a delivery is near, less often otherwise, quiet at night, and delivered parcels are not fetched again.
Depending on what a carrier makes available, devices can provide:
| Carrier | Data currently retrieved |
| PostNL | Tracking number, sender, receiver, status and status history, delivery date and window, PostNL Point, weight and dimensions, shipment type, direction, shared accounts, plus mail items with scans. Delivery image with the current status. |
| DHL | Tracking number, sender, receiver, status, delivery date and window, ServicePoint / ParcelStation, out for delivery, ready for pickup, recently delivered, sent parcels, last event and history. |
| DHL Express | Air waybill, sender, receiver, status, delivery date, origin, destination, service, pieces, last event, proof-of-delivery link and sent shipments. |
| Post & DHL Germany | Tracking number, sender, status, delivery date, Packstation / post office with address, returns, sent parcels and letter announcements. |
| DPD | Tracking number, sender, receiver, status, delivery date and window, ParcelShop, weight, dimensions, last event, history and sent parcels. |
| GLS | Tracking number, sender, receiver, status, delivery date and window, ParcelShop, weight, dimensions, last event and history. |
| UPS | Tracking number, sender, status, delivery date and window, service, origin, destination, UPS Access Point and last event. |
| FedEx | Tracking number, sender, receiver, status, delivery date and window, FedEx location, service, weight, dimensions, last event and history. |
| Budbee | Tracking code, sender, status, delivery date and window (ETA), Budbee Box location and pickup deadline, sent/return parcels and last event. |
| Vinted Go | Tracking number, item, status, pickup point, pickup code, sent parcels and last event. |
| InPost | Tracking number, sender, status, Paczkomat / locker, pickup code (account), out for delivery and last event. |
| bpost | Tracking number, sender, receiver, status, delivery date and window, stops until you, pickup point, weight, dimensions, sent parcels and Mail Ahead letters. |
| Royal Mail | Tracking number, order reference, recipient, status, shipping date and last update. |
| Ampère | Barcode, sender, receiver, status, delivery window (start/end), last event and details link. |
| Trunkrs | Tracking number, sender, receiver, status, delivery date and window, out for delivery, last event and history. |
| Dynalogic | Order number, sender, receiver, status (delivered, out for delivery, problem, returning), last event and history. |
| Dragonfly / Intelcom | Tracking number, sender, status, delivery date and window, out for delivery, sent parcels, last event and history. |
| Mondial Relay | Incoming and sent shipments of your account with sender and latest step. Mondial Relay does not share a reliable status yet, so status-based cards (such as delivered) will follow later. |
| Amazon | Shipments of your orders with item, delivery carrier, expected delivery date, out for delivery, ready for pickup and delivered. |
Every carrier has Flow cards for new parcel, status changed, tracking event, out for delivery, delivered and problem (plus ready for pickup, sent parcels and delivery time changed where the carrier supports it), conditions such as a parcel has status…, and actions to track, stop tracking and remove delivered parcels. Triggers fire once per change, also after an app restart.
Widgets (MyParcel Pakketten and MyParcel Bezorging) show your upcoming deliveries of all carriers directly on your Homey dashboard.
Supported functionality may differ between carriers because each delivery service provides different account and tracking information.
Documentation
All carriers, Flow cards, tokens and widgets are described in the MyParcel documentation (Dutch and English):
Carrier availability
Several parcel carriers do not provide a public consumer API for all functionality used by their official apps.
When MyParcel uses such an interface, changes made by the carrier can temporarily affect part of the integration. Wherever possible, MyParcel keeps the device available, shows a warning with the last known data, and indicates which functionality is temporarily unavailable instead of making the complete device unavailable.
Because carrier systems are maintained independently from MyParcel, functionality can occasionally require an app update after a carrier changes its API, website, mobile app or authentication system.
Important: Always use the same e-mail address or account that is registered with the corresponding carrier’s official app or website.
Download MyParcel in the Homey App Store
Encountering any issues? Help us help you by sending a detailed diagnostic report through the Homey mobile app.
More → Apps → MyParcel → Settings wheel in the top-right corner → Send diagnostic report
Please include your email address and a description of the issue in the input field so we can assist you more effectively.
When reporting an issue, please also mention which carrier is affected.
Changelog
Follow the MyParcel changelog for the latest additions, carrier integrations, fixes and improvements.
Apps made by @LRvdLinden
See more apps using the link below 👇🏻 or simply open the pull-down.
Contribution
If you appreciate this app, fuel future development with a PayPal contribution, buy a round with iDeal or Bunq.me.
Your support helps keep development going and makes it possible to add more carriers, features and improvements to MyParcel. ![]()
