[APP][Pro] Mitsubishi WF-RAC - Cooling, heating and ventilation
I will receive my Mitsubishi AC within a few weeks. I was wondering if this app also measures the power usage? Like current wattage and/or total Kwh
No, it does not.
Concerning Temperatures: it obviously requires a translation table (from read values to temperatures).
I did some PHP script to read out all current settings, and also to change the settings (after some Internet research and own reverse engineering).
Can gladly provide it - if someone can need it.
Sample output:
LED Status WiFi Adapter:   0
Model Nr:                  0
Running:                   off
Operation Mode:            Cool
Vertical Wind Direction:   High
Air Flow:                  Auto
Preset Temperature:        26
Horizontal Wind Direction: Left / Center
3D Auto:                   off
Indoor Temperature:        25.5
Outdoor Temperature:       9
Electricity Consumption:   0
Interestingly the Electricity Consumption is provided in the returned data block (if I compare to other code that can be found at the Internet), but it always contains 0 for me (although the Smart M-Air app shows values) - no idea here …
any progress?
if necessary i want to test it?
There is a official app now
Yeah, you are posting in the app topic. :wink:
See the first post in this thread.
Thanks for the great app!
Question: would it be possible to switch the airco also to Eco, Hi and/or Silent mode?
Thanks again
I’m having issues with the app. I cannot control my A/C with it: just nothing happens.
I checked my IP-address, which is fixed. It seems that the temperature is correctly received in Homey, and I saw the ‘outside temperature’ also changed. But other controls are doing nothing (I also waited for a few second delay).
How do I fix this?
Hi Renzo,
Can you restart the app, send a few commands to the A/C, then send a diagnostic report and report the UID here?
– Edwin
Hi Twan,
Unfortunately, this isn’t possible right now, and I don’t know when and or this will be possible in the future.
When I find out how, I am certainly adding this to the app.
– Edwin
Yes! 7afc35f6-c265-45af-ab28-c23cbcb54d17
I cannot see anything strange going on in the logs.
The commands are being send to the A/C as it should be.
How do you verify that nothing happens?
The connection between Homey and your A/C is extremely unstable (see the error logs).
You should try to fix that if possible.
Error logs
2023-08-16T15:56:27.765Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T16:03:28.234Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T16:04:28.322Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T16:13:28.955Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T16:16:29.190Z [err] [Device:a07d…] Sync error: api.connection
2023-08-16T16:16:29.192Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T16:19:29.423Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T16:29:30.171Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T16:31:30.301Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T16:36:30.695Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T16:43:31.152Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T16:44:31.261Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T16:48:31.612Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T16:55:31.875Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T16:59:32.171Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T17:10:32.907Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T17:11:32.949Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T17:12:32.999Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T17:16:29.434Z [err] [Device:a07d…] Sync error: api.connection
2023-08-16T17:16:33.393Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T17:17:33.487Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T17:18:33.595Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T17:28:34.429Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T17:30:34.607Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T17:32:34.752Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T17:36:35.165Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T17:37:35.165Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T17:39:35.235Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T17:40:35.333Z [err] [Device:b2cc…] Sync error: api.connection
2023-08-16T17:43:35.645Z [err] [Device:b2cc…] Sync error: api.connection
It’s verified that nothing happens. It’s stays off when I turn it on and vise versa.
My homey is connected via Ethernet. And the A/C unit is in clear sight of the access point 3 meters from it so I really don’t know how to make it more stable.
Is an api error ‘unstable’ or is there an error in the api?
It means Homey cannot reach the A/C on the network.
That is not what my router is reporting. So there is something else…
Edit: @evdpol how do you explain that commands arent send/received? But status infor is passed through?!
I have 2 units connected and they work pretty well with Homey. So thanks for making this possible. however I have 1 problem and I cant find a solution for it.
Before hooking it up to the wifi I could use the self clean function on the airconditioning. The manual says it should also be possible with the wifi unit but I can’t find it.
I would really like this function as it eliminates any odours from the units.
Am I missing something or is it just not possible?
Hi Arrow,
It is not possible to enable / disable the self cleaning function of the airconditioner.
This is possible via the Smart-M-Air app, but not how Homey talks with the A/C, sorry.
– Edwin
Thank you for the clear answer. No need to be sorry.
I’m sure I can build a workaround using flows.
Hi Renzo,
I am now also experiencing the “connection error” myself…
I have to troubleshoot when I have the time, strange…
Will keep you informed.
– Edwin
My airconditioner works like after 5 minutes, so I think it has to do with the amount of requests and a cooldown.
I made several improvements to the code which drastically lowers the amount of requests, and will be releasing a new version of the app when this is proven to be more stable.
– Edwin
