App Store Page: Mitsubishi (WF-RAC) | Homey
Description
Control your Mitsubishi Heavy Industries air conditioners from anywhere with Homey.
Check the temperature of your room(s) on the go, and if needed, turn on your air conditioner before arriving home. Unsure if you left the air conditioner on? Simply switch it off remotely using Homey.
To use this Homey app, your air conditioner must be equipped with a WF-RAC WiFi adapter and configured through the Smart-M-Air app.
Please note: This Homey app is NOT COMPATIBLE with models that use the newer INWFIMHI001I000 WiFi adapter, configured via the AC-Cloud app.
Instructions
Add the device as you would add any device to Homey. A polling frequency of 30 seconds is used to update the current status of the device in Homey.
Limitations
Remote control
When using the external remote to control the device, all settings are sent to the device, overwriting its current settings. For example, if you power off the device using the remote and the airflow is set to “high” in Homey but “low” on the remote, the “low” setting will be sent to the device. This will trigger capability changes.
Rate limit
There is a 1-second delay after each message sent to the device. If you send more messages than the device can handle, it will start behaving unpredictably. To prevent this, commands sent to the device are merged and sent every 0.5 seconds. This approach reduces the likelihood of overwhelming the device and ensures smoother operation for your workflows.
Temperature sensor
The device’s temperature sensor is likely to show a higher reading than the actual temperature. Unfortunately, there’s nothing I can do to address this. I recommend reaching out to your dealer to inquire about the issue—and please let me know if you find out anything. This discrepancy is unrelated to this app.
Donations
I enjoy creating apps for Homey and strive to support them to the best of my ability. If you enjoy using my apps, a donation to acknowledge the time and effort I put into them would be greatly appreciated.
FAQ
My device is unavailable. What should I do?
- Ensure there is nobody logged in via the Smart M-Air app.
- Ensure the device has a static IP address assigned by your router.
- Have you added extra mobile phones to the Mitsubishi Smart M-Air app?
- Keep in mind that the Mitsubishi device can support a maximum of four accounts.
- Has anything changed with your Wi-Fi setup, such as the access point being moved?
- Note that the internal Mitsubishi units have a very weak antenna, which may affect connectivity.
My device is not responding to any commands via Homey.
Delete the device from Homey, reset the WiFi module and try again. Chances are there were already 4 accounts registered on the unit before it was added to Homey.
How does vacant property mode work? (development)
Not all devices support vacant property mode!
When your device does support vacant property mode and you enable this, it will automatically sets the temperature to the last known temperature which was set when this mode was enabled (default: 10°C). When you disable vacant property mode, it does it the other way around.
How do the minimum and maximum temperatures work? (development)
- Your unit does support vacant property mode:
- You set temperature from 10°C to 17°C, it will switch ON vacant property mode and sets the operating mode to heating.
- You set temperature from 18°C to 30°C, it will switch OFF vacant property mode and sets the operating mode to the mode before it was in vacant property mode.
- You set temperature from 31°C to 33°C, it will switch ON vacant property mode and sets the operating mode to cooling.
- Your unit does not support vacant property mode:
- You set temperature from 10°C to 17°C, it will revert to the minimum of 18°C.
- You set temperature from 18°C to 30°C, it will set the selected temperature.
- You set temperature from 31°C to 33°C, it will revert to the maximum of 30°C.
