[APP][Pro] Life360
Does give anything else then timeouts
Logging nags about a empty password duels but it’s filled no need to doubt that
App is broken atm .
I’m on latest v5 firmwares
Same here.
I get this Error:
Settings Pagina
Life360 Instellingen
{ synctime: ‘3’, homerange: ‘100’, invisble: ‘false’, username: ‘Life360@xxxxx.nl’, password: ‘l8B^axxxxx@5uS’ }
New settings:
settings
Update Settings:
2020-11-19 15:56:19 [err] [Life360App] Unhandled Rejection at: Promise { Error: No password specified. at /node_modules/life360-hack/index.js:23:25 at Promise._execute (/node_modules/bluebird/js/release/debuggability.js:313:9) at Promise._resolveFromExecutor (/node_modules/bluebird/js/release/promise.js:488:18) at new Promise (/node_modules/bluebird/js/release/promise.js:79:10) at Object.module.exports.authenticate (/node_modules/life360-hack/index.js:19:10) at Life360Driver.getSession (/drivers/life360/driver.js:233:34) } reason: Error: No password specified. at /node_modules/life360-hack/index.js:23:25 at Promise._execute (/node_modules/bluebird/js/release/debuggability.js:313:9) at Promise._resolveFromExecutor (/node_modules/bluebird/js/release/promise.js:488:18) at new Promise (/node_modules/bluebird/js/release/promise.js:79:10) at Object.module.exports.authenticate (/node_modules/life360-hack/index.js:19:10) at Life360Driver.getSession (/drivers/life360/driver.js:233:34)
Error: No password specified. at /node_modules/life360-hack/index.js:23:25 at Promise._execute (/node_modules/bluebird/js/release/debuggability.js:313:9) at Promise._resolveFromExecutor (/node_modules/bluebird/js/release/promise.js:488:18) at new Promise (/node_modules/bluebird/js/release/promise.js:79:10) at Object.module.exports.authenticate (/node_modules/life360-hack/index.js:19:10) at /drivers/life360/driver.js:224:55 at tryCatcher (/node_modules/bluebird/js/release/util.js:16:23) at Promise._settlePromiseFromHandler (/node_modules/bluebird/js/release/promise.js:517:31) at Promise._settlePromise (/node_modules/bluebird/js/release/promise.js:574:18) at Promise._settlePromise0 (/node_modules/bluebird/js/release/promise.js:619:10) at Promise._settlePromises (/node_modules/bluebird/js/release/promise.js:699:18) at _drainQueueStep (/node_modules/bluebird/js/release/async.js:138:12) at _drainQueue (/node_modules/bluebird/js/release/async.js:131:9) at Async._drainQueues (/node_modules/bluebird/js/release/async.js:147:5) at Immediate.Async.drainQueues [as _onImmediate] (/node_modules/bluebird/js/release/async.js:17:14) at processImmediate (internal/timers.js:456:21)
start session
2020-11-19 15:56:18 [log] [ManagerDrivers] [life360] Init driver
2020-11-19 15:56:17 [err] [Life360App] error reading logfile: ENOENT: no such file or directory, open ‘/userdata/log.json’
2020-11-19 15:56:17 [log] [Life360App] capturing stderr
Which version of homey do you use? At the moment I am still not running v5. So maybe this is on v5. My homey is really slow and I have to much automations/app. So I need to have the pro. But I found it really to expensive so I am currently exploring home assistant and not sure if I keep my homey and if able to contine develop my apps.
I’m running v5 indeed . Time you switch since it’s more stable then the v4 stable already
I am on V5 and app is doing ok overhere
Where you already paired with the api . Since the trouble seems to be connecting to it for the first time .
Yes, allready paired
If I have some time during XMas I will look to this issue.
Probably you can also look it the wrong signaling in the “and” flowcard of the app.
The icon is a exclamation mark even when it’s a positive!
To prove it I made a test flow: Shared Flow | Homey
When I tell homey I’m away (not at home, icon greyed out) it keep working and therefor acknowledge that the app is working perfect.
Screenshot_20201212-131114|230x500
Hi, I have reset my Homey and installed V5. Then I installed the life360 App without problems. I wondering if a complex password that includes weird chars like ’ or @ can be the problem.
I will look to this as well.
I have a simple password welkom123 :joy:
Could you send me the logfile? To check what could be wrong?
Test version “and” command fixed.
Cool, can you share the beta link?
Looking good to me!!!
Thank you.
indeed looks to be working !
@Marcel_Visser i have the same issue. Did you find a solution for it?
Sorry I’m not using this app anymore…
