[APP][Pro] Life360
Sinds 14 dagen doet hij het niet meer,
Nu kan ik niet meer inloggen ook,
Via de officiële app wel…
Wat kan het zijn?
see above.
So you are carrying 2 phones with you at all times ?
Or
leaving the old one at home, but have to remember to keep it charged?
Br
Dennis
On Facebook, I see some (mixed) experiences that Life360 was updating values again.
I had uninstalled the app already and can not get it to logon.
But a few users that still had the app and devices reported that it was working again.
More users here that can confirm?
it looks like its updating again
That sounds great, but I am still not able to logon again after re-installing the app and devices.
Did you still have the devices installed in Homey, @Ype or did you add the app/devices again?
Life360 works for me on HA with ha-life360
still had them installed
Marc
i installed life360 on HA using HACS, and its been working for almost a day so far but when i use the HA plugin for homey it doesn’t find life360, just the other devices i have linked like my roku, ping etc… Could you tell me how you integrated the HA life360 with homey using the Ha plugin or did it require a workaround!
Any help would be appreciated… thanks
Homey’s HA App
Git hub to install Life360 on HA (i used the sign in method)
Homey HA image trying to add
HA Life360 image using HA to track
I am new to Homey and I installed the life360 connector but I can not login. I can use my credentials on the life360 website to login but not in the app. any ideas?
Hey Everyone, I’ve been using owntracks with some success but i am trying out IFTTT’s new group locations applet and it seems a little basic but i was wondering if anyone has also tried it?, or knows how to get the Locations applet to use tags to trigger a flow?.
1 test was I signed into both phones under my ifttt info and setup applet’s to trigger a different named flow on each device but it only gave me errors using tags or would trigger both flows on each phone at the same time… This seem like it would work but since i only know the basics of how tags and IFTTT work, i cant troubleshoot the problem… Any how2s or thoughts would be appreciated… Thanks
I requested they give us the option to start flows based on the members of the group and not the whole group but I’m not sure if that will actually go anywhere
these were the 4 i made 2 on each phone
i tried both these flows
basic
Advance
Hello, are there instructions on how to link the HandyappLife360 with the homey app Connect Life360?
can you show print or explain in andorid automative. cant figure out the http request
can you show print or explain in andorid automative. even the flow that accept the webhooks. cant figure out the http request
Hi, same issue!
May someone could help ?
Thank you
It appears my connection stopped working about 4 months ago.
I have tried reentering my credentials and saving them and restarting the app, but it’s still not working. In the Log, I have seen a Forbidden message, so maybe Life360 have changed something in the API?
I was going to copy the app settings log, but it seems that’s not possible.
I have sent a diagnostic log: b01f9388-c3a0-4cdd-8409-ed4de69df918
You can create a dedicated topic, you don’t have to wait.
Here you can found a (beta) working version of Life360
An working version of Life360 can be download here including a map widget for Homey Dashboard:
Community topic for feedback or tips can be found here:
