[APP][Pro] LG ThinQ - Smart living starts with LG ThinQ (Community) (NL)
@Martin_Verbeek Myauroc is connected via your app and I see in the device energy consumption, but when I click on the new homey energy tab I didn’t see the airco
Is that right
That might be fixed in 4.0.0 which uses the new API, currently not spending time in fixing the live version.
Oh that’s a quick answer! Thank you, do you have any eta when the new version will come then?
Hi Martin. Again thanks for your great work. I now have a dynamic contract and my washing machine starts at the cheapest moment. Now i see energy consumption in the QTinq app. Will this also be vissible in your new app?
When you start the awsher, do you also select a specific program in the flow to run? or just start the machine?
Hi guys. I’ve noticed LG has his own ThinQ app now. Are there differences with this one? I’d rather not swap for a new Thinq app, because of the hassle it’ll take…
I just tested it, it’s lacking lots of features like power measurement and flow control. The ui also caused my airco to switch modes and the device icons are weird.
But it does include tvs also.
And already based on the new device classes etc. It does have multiple thermostat settings for heat or cool modes etc. So that’s nice.
I won’t switch so far.
Thansk man! I won’t switch then. Everythings working fine now. Wouldn’t wanna mess it up!
I have a LG washing machine. I stick to the community app. It gives more possibilities.
Yes please we Need Dishwasher integration
Will the community app being supported in the future? For example will energydashboard supported with the Energy consumption shown in this app?
Yes it will.
So it turns out that the Energy dashboard requires the device to expose the meter_power capability. It should be a total value, so it can increase. That makes them show up as consumers of power.
(fixed)
Hello Martin,
The tiles in the Homey app do not show the correct set temperature for the air conditioning when changed manually or via a flow. This is a bit inconvenient if you then want to change the temperature via the app and it is not at the correct temperature.
Can you post a screenshot of the tile and the screen where the temp is set? Thx
Thanks for your work!
Looking forward to v4 as flow cards for my fridge is not working properly (and the official LG app is a joke).
(temperature value in “The temperature changes” shows target temp data instead of real temp)
My freezer is not currently supported.
Is there any data I can provide in order to help you in the process of releasing v4?
My fridge/freezer models are…
Fridge: GLM71MBCSF.AMBQEUR
Freezer: GFM61MBCSF.AMBQEUR
Hell of a job, but have things backward compatible now. Checking out the flows now.
@Martin_Verbeek do You have a update when you publice the new version?:blush:
@Martin_Verbeek Is all te above also the reason why my washing machine flows dont work anymore? I woul hate to use the official LG app because it is so limited.
