[APP][Pro] HDashboards Companion - The Homey Dashboard
HDashboards - the Homey Dashboard
Nederlandse post vind je hier
This post is made in consultation with Menno van Hout, the founder of HDashboards.
His vision is to make a Homey Dashboard that’s good, reliable and customizable. HDashboards works real-time, connecting straight to your Homey’s Socket.io.
*Note: this is a community made dashboard released in august 2023, not the homey dashboard which released its beta in oktober 2024. To find the differences, please check FAQ (5.1.2).
This post contains the following chapters:
  1. Why and when did HDashboards start?
  2. What are possibilities of HDashboards?
  3. How does the HDashboards companion app work and what options does it have?
  4. Community, tutorials, help and contact.
  5. FAQ (Frequently Asked Questions):
1. General
1.1 Who is the founder of HDashboards?
1.2 Why would I choose for Hdashboards while homey has it’s own dashboard?
2. Technical/issue’s
2.1 Is HDashboards secure?
2.2 Why do i have a different layout on different devices?
2.3 HDashboards says homey is offline, how to fix that?
2.4 How does HDashboards connect to homey?
2.5 On which platforms does HDashboards work?
2.6 After a refresh, my colors reset.
2.7 I Can’t Access My Dashboard on Any Platform / I Changed My Password – What Should I Do?
2.8 How do I transfer my lay-out to a new homey?
3. Guides/showcases
3.1 Are there examples of dashboards?
3.2 How can i change the background?
3.3 How can i make advanced graphs?
3.4 Can i upload pictures to HDashboards?
3.5 Can I show my trash dates on the dashboard?
3.6 Can I show timers on the dashboard?
3.7 How to display your current location and travel times?
3.8 How do i show my calendar on the dashboard?
3.9 How do I change the colors of a tile?
4. Feature requests/bugs
4.1 I found a bug/have a feature request, what do i do?*
4.2 How can i give attention to feature requests?
5. Other
5.1 What does HDashboards cost?
5.2 What is HBeat?
5.3 What are the HDashboards color codes?
5.4 Where do I find my invoices?
1. Why and when did HDshboards start?
HDashboards was registered on the 21st of August 2023 and started in beta stage in september 2023. The founder Menno van Hout, wanted to make a dashboard thats easy to create, but also has andvanced possibilities. Since the beginning, there have been many performance and feature updates. Within one year after launch, we have: 3300 users, over 6.800 dashboards, over 73.000 dashboard cards
2. What are the possibilities of HDashboards?
• Create multiple dashboards: you are able to switch between dashboards by flow or by opening it on the device.
• User management: Be in control of your house. Full permission system choose who can “view”, “use”, “edit” and “share” the devices and dashboards.
• lock tiles behind pincode: be able to lock your alarm system, temperature, locks and other devices until a pincode has been successfully pressed.
• Create a different layout per device: the layout will be safed per amount of horizontal squares (in edit mode), this makes it possible to make certain cards bigger on a bigger devices than on a smaller phone.
• Speaker cards: use the speakers connected to homey on your dashboard. Note: layout depends on the card size).
• Flow card: start an homey flow by pressing a card on your dashborad.
• Device card: select your homey device and show a value (capability) on your dashboard.
• Flow token card: select your home variable/flow token and show the value on your dashboard.
• Thermostat card: select your thermostat device in homey and controll it on your dashboard. Note: layout depends on the card size).
• Open dashboard card: open another dashboard (page).
• Multicard: make it possible to add multiple devices, titles, flow tokens etc inside one card.
• Clock cards: add dan clock on your dashboard.
• Title card: add a text on your dashboard.
• Image card: show your homey images on your dashboard or use any image link to show the image on your dashboard
• Video card: add direct video links (also mp4) and rtsp links to play on your dashboard.
• Timeline card: shows your homey timeline (possible to add a filter)
• Webview card: makes it possible to add websites. (this one is often used by homewizard p1 users) . (This card may not always work on all platforms).
• Calendar card: this card supports ICS files like the google and microsoft calendar. Make sure you use your secret address instead of the public one as the public does not contain your appointments.
• Background: you are able to add your own picture as background.
• Gauge Meter: Select a numerical variable to display, with an arrow that, depending on the value, points to colors of your choice.
Click here for the video about the gauge meter.
• Battery card: shows battery status of devices below a certain level.
Note: there are more options by using the HDashboards companion app, please read the next chapter for more information.
By using the hdashboards companion app, you get the following extra options:
IF cards:
  • IF any card has been pressed (Card ID can be found/changed by editting the card in HDashboards and pressing the advanced button)
  • IF a dashboard has been opened (by a certain user)
THEN cards:
  • THEN: change background color of the card.
  • THEN open a dashboard X
  • THEN refresh dashboard for user X
  • THEN send a notification to user X (for Y amound of time)
• The HDashboards companion app can be downloaded from here.
• In order to safe settings in the cloud, please add the key (in your HDashboards account) into the hdashboards companion app configuration settings: press companion app in the menu, follow this video tutorial or folow the first 2 steps in this written tutorial:
  • Our facebook community can be found here.
  • Our discord community can be found here.
  • Our tutorials can be found here.
  • Our community tutorials can be found here.
  • Our blogs can be found here.
  • Contact with Menno van Hout, founder:
    info@hdashboards.app
We have an very active community that’s always willing to help. We even organize live events
1. General
Menno van Hout is the founder of HDashboards. When he created HDashboards, he worked for a big software company. A couple of months after creating HDashboards, he started to work for Athom (Homey). Nowadays, he works as a freelancer.
HDashboards really stands out with some impressive features. The ability to control dashboards through flows, integrate RTSP streams, and assign unique actions to each tile via flows makes it highly versatile. Plus, the fully customizable grid layout gives you total control over the design.
Other major advantages of HDashboards include colored tiles based on status, displaying a large amount of variable text, support for multiple Homey devices, the gauge meter, and a full user management system. These features can be game-changers for many users.
Below you ll find an overview of different functionalities:
Functions Hdashboards Homey Dashboards
For android, ios :check_mark: :check_mark:
For web (car/casting) :check_mark: -
Integrated in homey app - :check_mark:
Multiple homey’s :check_mark: -
Show variables/ flow tokens :check_mark: :check_mark: (only short ones)
Start a flow :check_mark: :check_mark:
Show/use devices :check_mark: :check_mark:
Show/use speakers :check_mark: :check_mark:
Show timeline :check_mark: (incl filters) :check_mark:
Webview (html) card :check_mark: :check_mark:
Show battery status of devices :check_mark: :check_mark:
Camera pictures :check_mark: :check_mark:
Camera streams :check_mark: -
Show video’s :check_mark: -
Show insights :check_mark: (workaround) :check_mark:
Show weather :check_mark: (workaround) :check_mark:
Multiple dashboard pages :check_mark: :check_mark:
Control dashboards by flow :check_mark: -
Customizable background :check_mark: -
Widgets made by appdevelopers - :check_mark:
Layout adjustable per device :check_mark: (max 3 rows)
One-click on device triggers an action by flow :check_mark: -
One-click on device can be locked :check_mark: -
Tile colors can be changed by flow/status :check_mark: -
User management/privacy :check_mark: (view/use/edit/share rights) - everybody can view/use and change everything
Gauge meter :check_mark: -
Price 25 euro /year up to 25 euro
Yes, HDashboards runs fully local, we only store layouts in the cloud. No device information will be safed (UUID’s only). We follow all the regulations of the Dutch Law. Hdashboards uses a on to on connection to Homey.
The layout will be safed per amount of horizontal squares (in edit mode), this makes it possible to make certain cards bigger on a bigger devices than on a smaller phone. If you want to edit the layout of your tablet on a pc, just check out how many horizontal squares the tablet has, go to the menu of the pc, and change the “max width” of the pc to the same amount your tablet has.
The maximum width can also be changed per dashboard. Just head to the dashboards screen, edit the dashboard and change the max width there.
It might occur that HDashboards gives an “homey offline” error. This error most often occurs when the homey cloud has or has had issues. To solve this issue, restart your Homey and force close the HDashboards app.
HDashboards tries to connect using a direct (socket) connection to your dashboard. If not possible, the data will be sent using the athom cloud.
HDashboards uses an cloud in Amsterdam. The cloud is used to store images you uploaded on the hdashboards website, to store layout and to transform image links. No device/flow data will be stored in the cloud. We do safe your name, payment information and email adress.
HDashboards works on web
HDashboard works on android.
HDashboards works on IOS.
Please make sure you add the key into the app settings of the companion app. Check written tutorial step 1 & 2 or video tutorial .
Note: on some devices, the key might not be fully visible. Make sure you select the full key before copying.
If you’re unable to access your dashboard on any platform and encounter a login error, you can likely resolve the issue by visiting the HDashboards website and selecting ‘Register Homey.’ This problem often occurs after changing your Homey’s password
If you bought a new homey and replaced an backup, you are able to transfer your dashboard aswell! Just go to the main website of hdashboards and register your new homey. Once you login on the main website, you ll find both your homeys under ‘home’. Press the blue ‘transfer’ button to transfer your dashboard.
3. Guides/showcases
Please check the gallery here.
Go to the dashboard page, press edit, edit the dashboard and you ll find the option the change the background and transparency of the cards.
Please check this tutorial.
Yes you can upload your picture here and press on the eye icon. You can now copy and paste the link into an image card.
Yes, check the tutorial here.
In order to display (current) locations, travel times, traffic jams or other information based on gps/coordinates, you could check this information and the “Here Free location & map services” app.
In order to show calendar items on the dashboard, please check this tutorial.
In order to change colors of the tiles, please check this guide.
Feature requests can be added here.
We try our best to reduce the amount of bugs as much as possible. We do have a test team for android, ios and web. Yet, bug may happen. Bugs can be reported here.
Once per month, you ll 3 get votes to give some feature requests more attention.
5. Other
We offer the following packages:
  • FREE Trial: 14 Days access, 1 User, Unlimited dashboard, Unlimited Cards, Single Homey,
  • € 25: Standard, 1 Year access, 10 Users, Unlimited dashboard, Unlimited Cards, Single Homey
  • € 20: 1 Additional Homey, 1 Year access, 10 Users, Unlimited dashboard, Unlimited Cards, Multi Homey’s (+ 1 homey)
5.2 What is HBeat?
HBeat is a tool that checks the status your homey every 15 minutes. If your status changes from online to offline or the other way around, i twill actively send you an email to notify you.
Dark Mode:
  • Background (black): #121212
  • Card background (dark grey): #1E1E1E
  • Device on (green): #1D4A36
Light Mode:
  • Background (pale blue-white): #EFF1F6
  • Card background (white): #FFFFFF
  • Device on (green): #56C78E
5.4 where do I find my invoices?
Your invoices can be found here.
Dark Mode:
Other questions? Feel free to ask
I have said it before, but I would like to express once more how happy I am with this dashboard solution. It’s so easy to set up and create a basic dashboard, whether it’s on a tablet, a phone or pc/laptop. Yet you can do amazing things with it after you deep dive into all of its features.
I am a ‘it-should-work-out-of-the-box’ kinda person. And still I would like to have the ability to do a bit extra if I want to. That’s also to reason why I chose Homey over other home automation platforms. This dashboard embraces that philosophy.
I will share some of my dashboards soon to give you an impression :sunglasses:
Some examples:
Wow! I love your creations!
This is beyond what i imagined when i created that feature haha! Awesome.
Anyone else who would like to share their creations? I am always looking for inspiration for my own dashboards.
Kind of jukebox! :wink: :wink: with a lot of Sonos speakers and Philips Hue lights!
That’s so awesome Joris!
Those rectangle tiles are really nice. I especially like the Bands jukebox. Love a consistant design.
Unfortunately I have Nest /Chromecast devices all over my house and the Spotify app for Homey is not supporting these… :frowning:
Can you please tell me briefly how you got the text on the weather tab?
Which text? The ‘Buienradar’ and ‘Hooikoortsradar’ links? These are actually dashboard cards. If you flatten a dashboard card, the icon disappears and only the text remains.
I meant the text in the middle with the temperatures and windspeed. Is that a multicard with different devices?
Multicard indeed, but with Flow Tokens. I use the KNMI app for that.
I’m gonna need to look into the flow tokens. Haven’t used it. I’ve been away for a long time. Thanks for the clarification mate
