[APP][Pro] Harmony Hub (v2.0.7)
Any idea what could be wrong with? Why is my hub not found ?
Did you ad remotes in the hub itself? The homey app should discover the remotes. Not the hub
My hub is in an other subnet, how can I add it?
homey: 192.168.1.x
harmony: 192.168.0.x
Both subnet can access each other, HA has no issue adding the hub in a different subnet, bu Homey cannot find it, also I cannot find any option to add it manually…
It was working for me until a couple weeks ago, now it cannot find either of my hubs. Tried uninstalling/reinstalling. Hubs are visible on my network, HA can see them.
Tried to some time ago. HarmonyHub needs to be in the same network
  • with Homey pro for Homey app to find it
  • with your mobile for Harmony mobile app to find it for local control.
So I ended up in keeping Homey, Harmony and mobiles on the same LAN.
I submitted a PR fixing the network discovery and added manual IP fallback.
Awesome update! I immediately tried it since my Harmony is in another VLAN then my Homey. Unfortunately it doesn’t find my Harmony. When I tried to add it to Homey using the IP address of my Harmony I’ll get the following error: Error: no Harmony Hub responded at [IP]. When I use my IP in the Harmony app the Hub is found, the same counts for when I try to add it to Home Assistant using its IP.
What could be the problem?
Edit: this was my own fault. My network settings were too strict. It is solved now :slight_smile:
hi, nice working app but (it seems like) v3.1.0 my devices are not working.
“Apparaat niet beschikbaar” Hub is offline.
Restart seems to work sometimes but not always.
Same here. Like many others. Is this app still being maintained @rkokkelk?
FWIW My log ID is ebb43869-da0c-4721-a81d-42e3d4ae079a
Any idea what’s going wrong @rkokkelk , here’s a new error ID: 510b2500-4873-468b-83ec-7ee65ca72c0a. Perhaps @jreenen or @denniedegroot know more?
