Im Homey nicht alles verfügbar wie im Harmony Hub
hi
warum sind in der Harmony so viele Einstellungen , z.b Eingang , Soundeinstellunge etc vorhanden aber im Flow der Homey nur die " wichtigsten" ein und ausschalten lauter leiser verfügbar ?
Danke
Weil die App so programmiert wurde?! :man_shrugging:t3:
Hier der offizielle Text aus der App-Beschreibung:
CAPABILITIES
During the pairing process the capibilities of devices and activities will get mapped to Homey capabilities.
OnOff
Capability for turning a device or activity on or off.
VolumeUp/VolumeDown/VolumeMute
Capability for controlling the volume level of a device or activity.
ChannelUp/ChannelDown
Capability for controlling the current channel of a device or activity.
FLOW CARDS
Flowcards can be used to build flows in Homey’s flow editor.
Triggers (when)
Application
To use the application cards select ‘Homey Harmony Hub’ in the ‘When’ column.
Activity starting
Every time an activity is about to start on your Logitech Harmony Hub this card will trigger. It provides 2 tags: - hub, this tag contains the hub name on which the activity is about to start. - activity, this tag contains the activity name of the activity that is about to start.
Activity started
Every time an activity is started on your Logitech Harmony Hub this card will trigger. It provides 2 tags: - hub, this tag contains the hub name on which the activity is started. - activity, this tag contains the activity name of the activity that is started.
Activity stopped
Every time an activity is stopped on your Logitech Harmony Hub this card will trigger. It provides 2 tags: - hub, this tag contains the hub name on which the activity is started. - activity, this tag contains the activity name of the activity that is started.
Hub inactive
This card can trigger if the hub is not active for an interval you choose: - 5 minutes - 10 minutes - 15 minutes - 30 minutes - 1 hour - 2 hours - 4 hours - 8 hours
It provides the name of the hub that is inactive as a tag.
Device and activity —————-#### Turned on Every time the selected device or activity is turned on this card will trigger.
Turned off
Every time the selected device or activity is turned off this card will trigger.
Conditions (and)
Application ———-#### Activity is/is’t matched This card can be used to check if an activity is equal or not equal to a specified activity. Although you can type in the activity name by hand I would suggest using a predefined activity tag (e.g. generated by the Activity started application trigger card).
Device and activity ——————#### Is on / Is off This card can be used to check if a specific device or activity is turned on or off.
Actions (then)
Application ———-#### Start activity This card will start a selected activity on a selected hub.
Stop activity
This card will stop the current activity on a selected hub.
Device and activity —–#### Turn on This card will turn on a specific device or activity.
Turn off
This card will turn off a specific device or activity.
Toggle on or off
This card will toggle the onoff state for a specific device or activity.
Mute the volume
This card will mute the volume for a specific device or activity.
Unmute the volume
This card will unmute the volume for a specific device or activity.
Turn the volume up
This card will turn the volume up for a specific device or activity.
Turn the volume down
This card will turn the volume down for a specific device or activity.
One channel up
This card will switch one channel up for a specific device or activity.
One channel down
This card will switch one channel down for a specific device or activity.
Send command (device exlusive)
With this card you can send a command registered in your Logitech Harmony Hub to your device (e.g. input hdmi 1, record program…). The logitech harmony hub is grouping this kind of command so first specify the group and then the command you want to have executed. You can also specify the ammount of times this command should be repeated where 0 is only one time 1 is executing the same command twice etc…
(VOICE) COMMANDS
- (Ok Homey,) Turn on [device or activity name]
- (Ok Homey,) Turn off [device or activity name]
- (Ok Homey,) Mute [device or activity name]
- (Ok Homey,) Unmute [device or activity name]
- (Ok Homey,) Volume up [device or activity name]
- (Ok Homey,) Volume down [device or activity name]
- (Ok Homey,) Channel up [device or activity name]
- (Ok Homey,) Channel down [device or activity name]
Gibt’s jetzt 2 Wallner? :thinking:
Du kannst auch den Programmierer anschreiben bzw. Dich informieren, ob es überhaupt möglich ist Deine Wünsche zu integrieren.
sorry war account am Handy
gibt es andere Möglichkeit ir Geräte ohne Harmony Hub zu steuern ?
Ist ja kein Problem, ich war nur irritiert.
Mir ist spontan Blastbot und Broadlink eingefallen, aber die werden anscheinend nicht unterstützt. Ich bin aber der Meinung, dass ich das ein oder andere schon mal im Forum gelesen habe. Vielleicht einfach mal die Suchfunktion nutzen.
