I am using HP19
@Martijn, thanks for your fast response and resetting the limit. But I am sure I did not reach the limit of 30 even not in 24h.
@Capetrip I’ll check that. Maybe the cache is not reset properly
New app update (
TEST: 3.30.0):
Changelog:
NEW:
1: NEW: update SDK to 3.1.1 (containing fixes for S350 and battery draining)
FIXES:
1: None
More - apps - Eufy Security - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
You can install the test version by clicking the link above and press install
Don’t want to be part of this test version? Install the live version → Eufy Security | Homey
@Robin_De_Lange please see above ![]()
@Capetrip I edited the rate limiter. Shouldn’t happen again ![]()
thank you, just tested but unfortunately same result. still only see the eufy picture.
d65c482a-d109-461c-947a-6f4993c43787 <<tested the flow couple of times
@Robin_De_Lange there was a error in the build. Can you check 3.30.1? Latest test version
Yes, it works now! thanks a lot!
@Robin_De_Lange Awesome! ![]()
I try to make an flow so lights get on when door is opened but some how i cannot get it working.
I have set push notifications on (eufy app send push when door is opened) and make an flow: when alarm is on then turn light on but some how it will not work. In eufy app i get the push when i open the door.
I wonder why there must be an alarm because in the eufy app the status of sensor is monitored and give open when i open it. Why must it be an alarm, is it not possible to get the status in homey?
Hi @Michael_PA4MIC
Please send a diagnostic report
No there’s no way to set it without notifications. If there was a solution I would of course enabled that.
This is not a official app and therefore there’s no official api
Edit can you also share your flow?
@Martijn, thanks ! Much appreciated!
Hello I have ordered a ‘Eufy Indoor Floor Lamp E10’.
Is ir possible to connect the product to homey?
No. You’d best search the app store
https://homey.app/en-us/apps/homey-pro/, or the best buy guide, before ordering. Except for Matter enabled lights, they should work without apps.
Or, maybe the Eufy Security & Eufy Clean app creator @martijnpoppen likes to add eufylife wifi products to his impressive range of apps one day? ![]()
@Michael_Zimmer i received my sample from eufy and I’m working on that. Will be part of the (mega) Eufy app.
@Marcus_Bitterling theres a dropdown on that screen. There are 2 images available for Eufy, event and snapshot. The one you use in your dashboard is probably the event image
for snapshots see FAQ Q14: [APP][Pro] Eufy Security - #4 by martijnpoppen
Stupid. Didn’t notice that, I’m sorry.
What’s the difference between event and snapshot?
