[APP][Pro] Eufy Security
Hi Martijn,
My c210 indoor pan&tilt isn’t recognised in the installation page. I tried all options and get an error every time, while I have recently added other devices that work just fine.
Checked the connected account and it is working there.
Can this camera be added? Or recognised in the indoor pan&tilt section?
@D_Wevers That is not available yet in the SDK see: [Feature request]: Support for Eufy - Indoor Cam C220 · Issue #496 · bropat/eufy-security-client · GitHub
(C220 and C210 are the same)
So once it’s available there I can add it to homey
@Robin_De_Lange can you try again? I changed something on the snapshot server
Just tested but nothing happens, I don’t know if there is a difference in an Event and Snapshot?
The snapshot image has never shown anything to me, I have to click on Event every time after which I get to see an image
@Robin_De_Lange ofcourse there a difference
A event image you get when a event occurs like person detection
Snapshot is the image you get when you run the snapshot flowcard (see FAQ q14)
Aah oke, the event works only the snapshot doesnt.:grimacing:
@Robin_De_Lange the 2 are totally different things so they’re not connected what so ever.
I would say check FAQ Q14 to see how the snaphots work, (if you;re interested ofcourse :smiley: )
Can you send a new report after trying the snapshot card a few times?
I didn’t see any confirmation from the server for the snapshot, so i guess it’s not working.
How is the camera connected? via a homebase or stand alone?
Haha i just did, thanks. I also looked at my settings in the eufy app. And that seems fine
The camera is standalone, i dont have a homebase. Only a micro sd card in it.
Just activate 6 times the flowcart make snapshot.
726127c6-d92c-453c-8130-2d1451916e01
Thank you
@Robin_De_Lange
Strange, it’s not activating the snapshot. Does the onoff work on the camera?
And is Homey in the same network as the camera?
Also a restart of the indoor cams might sometimes work for these issues
Just checked and yes this works.
Yes it is, static ip to.
Tried that multiple times, without succes
@Robin_De_Lange Hmm i’m not sure then. The S340 doorbell also doesn’t work with snapshots in standalone mode. So this might just be an issue with the S350 aswell.
I have to update the SDK anyway, so will check if there was a update in there.
Will come back on that :slight_smile:
Edit: yep there were fixes for the S350. Will try to update soon!
Aah great! Thank you for the help, i’ll send you a beer (or something else😂)
Thanks a lot man! @Robin_De_Lange !
Hi Martijn, seems snapshots again stoped working. I don’t get any snapshots seems a day or so. Could you please check the snapshot server again.
Many thanks !
@Capetrip its all good just tested.
Did you hit the limit of 30 per day?
@Capetrip can you try now?
No, I did not get to the limit of 30. just had 2 today and 4 yesterday.
When using the Web Homey Application
I am again get the error message when loading the image in the Honey App - see attached.
Posts have crossed. Now it works. Thanks ! What was the problem ?
@Capetrip yep that can happen it’s sending a 4 second stream to the server
It works perfect on HP19 but on HP23 there’s a work around required in the code. Causing it to be a flaky implementation. I need a fix from athom for that
@Capetrip i reset the requests. Aka the 30 requests list per user. It’s a 24 hour limit
