[APP][Pro] Duux Gen2
Thanks, works amazing!! Also a question, why is there a WHEN… Horizontal changed. But no WHEN… Vertical changed? (Same with AND…)
Because vertical oscillation is stateless. The Duux server doesn’t keep track of its state (in the Duux mobile app, the state also isn’t shown after restarting). This means that my app has no way to check the current state, so you can only set the vertical oscillation
Ohhh
Hi, did you get the issue fixed?
Hi, I have a question. I see that I can only set the horizontal oscillatie and not the vertical oscillatie. Is it possible to build that in this screen as well so that I can always set it manually? Maybe there is also another way where that can be set up manually, but that I don’t know could someone help me with that and explain where I can find that?
Because vertical oscillation is stateless. The Duux server doesn’t keep track of its state (in the Duux mobile app, the state also isn’t shown after restarting). This means that my app has no way to check the current state, so you can only set the vertical oscillation from a Flow
New toy!! :smiley:
Version 2.8.4
  • Remove DNS Cache from Elevate device
Version 2.8.5 [LIVE]
  • Fixed horizontal oscillation for Elevate
Does anyone have a Whisper Flex 2…? Can’t get it in pairing mode and GOOOD.. Duux is slow at replying.
Already tried holding the On/Off button for 5 seconds?
Yes, now Duux says mine isn’t a smart model… BUT THEN WHY IS THERE A WIFI ICON??
You literally see the wifi icon, but i can’t get it to flash…
Maybe they re-use the LCD panel for both WiFi-enabled and the “dumb” models to save costs?
When searching it up the model DXCF88 is a smart model… Duux has given me wrong information before… I can’t trust what they’re saying..
Are you sure? This is a result that I found:
It specifically mentions that the device is not “Smart Connected”.
:expressionless_face::expressionless_face::expressionless_face: oh well. I guess i’ll send it back to get a NOT DXCF88.. It’s so hard to find them in Norway right now though… :expressionless_face: (got it from coolshop.no) but the site is 404 now.
Version 2.8.6
  • Added icon for Elevate
Version 2.8.7
  • Update dependencies
If anyone has a Threesixty or Edge that’s not yet supported, please let me know. I see many automated reports from the app about type ID 20, I think it might be an (original) Threesixty or another variant of the Edge
Version 2.8.8
