[APP][Pro] Duux Gen2
Here you go.
“I can’t turn off horizontal or vertical oscillation in flow”
939f3edc-6776-46e8-b0fe-999ead8bc0c2
“Mode” also doesn’t work in flows but in the Homey button.
4ecfdaf3-97a4-475b-8d63-03fdbd49f7a5
Version 2.7.12
  • Fixed horizontal oscillation Flowcard for Whisper Flex
Can you try it again with the new test version?
The Flowcards should work again in this new version. Where do you see the percentage? In the fan speed slider, in Insights, in Dashboards or somewhere else?
The slider doesnt show any numbers at all, just the slider with up and down. But in the flow there is possible to adjust/slide from one to 26%, but selecting number from 1 to 26 is pherhaps more like the native app? But neither works. But now both “mode” and horizontal oscillation woks in flows, but not vertical like you explained (perhaps remove the card?).
Version 2.7.13
  • Added automatic sending of reports for unknown device types
Version 2.7.14
  • Fixed Flow cards for Whisper Flex
Nothing happens when I adjust speed and vertical oscilation in flows.
Version 2.7.15
  • Added condition card for Whisper Flex mode for convenience
Version 2.7.16
  • Update dependencies
Version 2.7.17
  • Added mode condition Flowcard for the Whisper Flex Ultimate
I installed my Whisper Flex 2 today. Adding it to homey pro was really easy. Thanks for your work Sven!
Do the Flowcards for oscillation and mode also work?
Yes they do.
Would be nice if it would be possible to switch between Natural Wind en Normal mode without a flow.
Maybe the Child Lock switch can be replaced and used for that ?
Should already be possible. Swipe to the right to use the mode selector or swipe to the left to access fan speed
Ok thanks, found it. Great !
In November we had made the Wisper flex working. Worked perfectly. However, today I take the fan and it turns out that the slider no longer works. All positions remain 0.
Version 2.7.18
  • Fix Whisper Flex fan speed
Can you try the new test version?
Thanks, now it’s working correctly again. Now I can optimise my flow.
Hi Sven,
If I want to set the speed of the Whisper Flex 2, I can only set a percentage instead of a number, like in the original Duux app. (1 - 30)
In your app the speed can be set from 100% up to 3000%. See below.
Could this be changed to the numbers like in de Duux app 1 up to 30 ?
Cheers,
Wim
