[APP][Pro] Domoticz - Control at your finger tips
Haven’t updated my domoticz yet so haven’t got time to check it. Maybe this weekend
never seen devices in this box but are they also not visible in Homey Devices?
I completely reinstalled my PI and domoticz and now I have my sensors visible again in Homey.
Thanks.
Hi, For a few months I have a raspberry pi installed with Domoticz. I completely reinstalled it 10 days ago after an update to Domoticz 2020. It’s working and I have installed the P1 smart meter cable. This week I bougth a Homey and try to install the Domoticz app. Whatever I put in the parameters I can not connect. I know the IP-address is correct because I can access the Domoticz panel. What should I use for port? the default 8080 also used to access the panel, or the ’ remote shared port’ which is in the settings, or nothing at all? And for login? the deault user/password for the pi? or a user defined in the settings of Domoticz?
this is all I dit for setting, no name no password.
thanx, but didn’t work for me. could be because it is not static ip but by dhcp?
As long as you can connect to the IP via your browser, it also should connect to Homey.
but what is exactly not working? Where do you expect something?
I get a timeout error (after 30 sec.). Should I configure the Domoticz? I see under settings, more-options the possibility to send data through http; do I need to configure that? The only hardware I have connected is the P1 msart meter cable which gets me Voltage L1/l2/l2, Usage L1/L2/L3, total, Delivery l1/L2/L3 (solar panels) and Gas. Besides that I have nothing configured.
Normaly there is nothing to configure, maybe a restart of the app or Homey can help, otherwise ask @Jeroen_Somhorst
Hi Jeroen,
Thanks for the app. The installation and configuration worked fine, but I’m only able to get T1, T2 and current power values. I’m missing the return values R1 and R2. On the domoticz side I can see them just fine. Is there something I’m missing or did wrong?
This is not implemented
anyone willing to take this app over from me? As you may have guessed i’m not that active anymore and I would like to give the app/source to someone who can / want to work on it
Attempting making it back available. But to update the code it is still a SDK2 version so a lot of work.
Would be highly appreciated! Keep up updated :slight_smile:
Code is running but pairing devices found from Domoticz serveris still a problem. Am on holiday break at the moment so no progress for now or some other developer has some spare time to fix that problem.
Ah Thérèse is comming a new app?
Because the old one is nog working anemore.
Old one is SDK2 and will not run on HomeyPro2023.
Trying to update it to SDK3 but that isnt easy and the original developer quit supporting it. But its best effort from my end as I also use domoticz and its features with Homey so will face same problems when I buy my HomeyPro2023.
This is very good news for someone who is preparing to switch from Domoticz to Homey pro. I am looking forward to your developments and good news.
I understand but have private problems that have priority over this development.
Alright…finally.
Those that still have Domoticz around here a SDK3 version.
