Power:
Gas
Something like this?
Excellent!
Very welcome!
Iām very happy with the progress of your app!
Its a perfect way to read out a smart meter with Domoticz!
Not something but exactly, great job, thanks very much
What is Ring for on top of Gas page with slider?
thatās nothing. That is something from my phoneā¦ it sometimes does that when I try to take a screenshot
I just updated github repo so for those who are brave. Install it from there. Also keep in mind that you need to repair the devices for this to work.
Keep up the good work!
Just got the update through the regular app store, works great! Was wondering if you could add a decimal point to the electricity t1 and t2 like the gas meter?
Great if i would get it to work. I have Domoticz on synology and that all works, but i cannot get it to work in homey it reports there are no devices configured yet.
What am i doing wrong? In the app i put the ip address from the domoticz server and the port 8084 on which i can see the domoticsz web page.
Iāve send you an PM
got it installed also now. It gets the gas and electric meter, but it is not showing any values.
while on domoticz it gives values.
i just needed to wait, now data is showing.
my domoticz app on the homey does not work. how do i install it and do i have to install something on my raspberry/domoticz or not?
You donāt need to install anything on your domoticz. If you installed the app you should go to more -> settings -> scroll down to the apps section and select domoticz app. You need to provide the following:
and then hit save. Next you should be able to add new devices. By going to the main screen of the homey app and go to devices and hit the + button
Hi Jeroen,
I installed the current and the beta version, but have issues getting it to work. Using the IP and the external address, with correct credentials I go thru the wizard and get āno new devicesā. If I use the ip/url with port an same credentials in Chrome, I do get a connection.
Your earlier version worked for me, I was trying to test the latest releases.
Hi
I cant get this to work
I try to connect with same ip and port as I do in The domoticz app, username and also The same password but I can not hit The save buttom, nothing happens, anyone know what Im doing wrong?
Iām currently working on the app again. As @Eternity correctly stated the app is currently a tiny bit broken . Donāt know when it will be fixed but iāll keep you all updated.
In the next version of the app I would like to introduce a new functionality. To group ādevicesā together. Currently when the app scans domotics it will let you show every single device as a single device. But in domoticz it could belong to the same hardware. For instance I have a P1 smart meter. Currently when i add it using the app it will show up as two separate devices in Homey. But in fact its a single device with two capabilities.
Before I make that change I would like to know what you all think about this. Keep it as it is now ( fixed )? Or group devices based on the hardware it belongs to?
Using version 0.1.4 beta and this version does the job for me. I switched in most flows from HTTP app to Domoticz app.
Plessers keep it this way.
So thanks for this app.
Gave the App another try. Tried the stable and the beta, but both donāt install devices for me. Will try again this weekend.
BTW
Why I installed the App again?
I have plans to set up a separate domotica system, controlled by a Xiaomi gateway. This is for my sons bedroom, and allows him to experiment.
We both can see the devices in the Mi App and in Domoticz (on my NAS), I thought that linking Domoticz to Homey would allow me to control the gear connected to the gateway
can you try installing the version that is currently on github (Betachannel) ?
Dit the CLI install and that works Jeroen!
I have only a few devices, and all showed up. Tested briefly, the Yeelight bulp does show up, but is not controllable. It times out.
95% okƩ!
