[APP][Pro][Cloud] P2000 for Homey (Dutch 112 (911) alerts
Thank you very much for your response.
Until recently, the apps were working perfectly. For your information, I would like to share the following:
The only change I have made is to my Deco Mesh network; I switched from the Deco M5 to the Deco Mesh BE65.
The operating mode for my Deco is set to the default “Wi-Fi router” setting.
I am also using a new phone.
I have noticed a difference between using the web version on my PC and the app on my phone.
In the web version, the “data source monitor” does not work; the P2000 screen is visible, but the connection is lost.
On the phone, the “data source monitor” works, but the P2000 screen does not.
If this information gives you any ideas, please let me know. Unfortunately, my own technical knowledge is reaching its limit here. Best regards, Peter
@Peter_Grootveld KPN has a blocked the call to our server. Only way to fix that is changing the dns settings in your KPN modem. To for example google dns or cloudflare dns. Most of the time this makes your connection a bit faster as well. You can find a lot of info on internet about this
Recommended search term: KPN Google dns
I understand that this might be a bit technical but unfortunately we can’t do much about it.
Edit: I’ll check with @LRvdLinden if we can change the domain name, that might fix this. It’s KPN veilig which is blocking us
@martijnpoppen Fantastic, and thanks for your response!!
I turned off “safe browsing,” and everything is up and running again!
Should it be possible to change the domain name, I look forward to seeing that solution in due course.
Much appreciation for your fantastic apps.
@Peter_Grootveld yes that’s exactly it. I made a DNS fallback for the APP.
@LRvdLinden will share a update soon, after installing that you should be good to turn on “safe browsing” again :slight_smile:
:rotating_light: Update 6.2.6
New Test version!
Fixed
:shield: Blocked by your internet provider: some users stopped receiving P2000 alerts because the filter of their internet provider, such as KPN Veilig Browsen, blocked the P2000 server. P2000 now detects this and automatically switches to secure DNS-over-HTTPS, so the alerts keep coming in. The connection is still verified against the real P2000 server. Big thanks to @martijnpoppen for this fix!
:glowing_star: Enjoy the latest version of P2000, now also reliable for users behind a provider filter! :rocket:
Visit A-alerts today and embark on a journey of seamless communication and heightened situational awareness! Your feedback continues to shape our evolution. :globe_with_meridians::mobile_phone::laptop::rocket:
Download
Download the new version in the Homey App Store!
:collision: If you find any issues, send a diagnostic report
:warning: Note: Before sending a report make sure to reproduce the issue so the issue will be visible in the report
  1. :mobile_phone: Via Homey Mobile app:
    More - apps - P2000 - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
  2. :laptop: Via Homey Webapp:
    Settings wheel bottom left - Select P2000 - Click on send diagnostic report
You can install this version by clicking the link above and press install (do not remove the app, only press install)
:fast_reverse_button: Don’t want to be part of a test version? Install the live version → P2000 | Homey
:police_car_light: Disclaimer :police_car_light:
This app is a labor of love, provided on a best-effort basis. No rights can be derived from its use. Data made possible by p2000.page
:laptop: Apps made by @LRvdLinden
See for more apps link below 👇🏻 or just open the pull down. From @martijnpoppen
Contribution
If you appreciate this app, fuel future development with a PayPal contribution, buy a round with iDEAL or Bunq.me. Your support keeps the magic alive! :sparkles::rocket:
Problem is still there 6951f382-c7e7-4936-8d8d-dd311c59a3ba
@Peter_Grootveld the log shows data from the server and no errors. :thinking:
@martijnpoppen When I enable “safe browsing,” I stop receiving notifications. If I disable it, the notifications return. The report was generated after enabling the feature.
@Peter_Grootveld
Can you enable the “safe browsing” feature, restart the p2000 app and then send a new report?
@martijnpoppen
Please find the requested report attached.
I have now observed that, with ‘safe browsing’ enabled, the P2000 app provide up-to-date information.
a5e775dd-9ad4-445d-99e5-62ddbdb1c827
Good to hear! That means the issue has been resolved. Thank you for confirming!
Checked the report. All good!
@LRvdLinden @martijnpoppen
Is this solution also being implemented in the other apps? Lifeliner is still giving the same problem.
