[APP][Pro][Cloud] P2000 for Homey (Dutch 112 (911) alerts
The app is working. Thit you try to reboot your HP?
I have the same problem.
I did reboot HP and the app, no result.
Try separate condiments cards?
Flow test won’t work with the p2000 app
For a couple of days i also didn’t get any notifications.
After a restart of the app it is working again.
Is it posible to make a flow:
een nieuw melding is ontvangen => Catergorie is Aardgas geconstateerd => maak een melding
Or is this not posible with category’s?
I think that does work with categories, but I’ve actually never come across the category “Aardgas”.
“Gaslucht” is more likely to appear in the report.
Well,
Not this way, anyway, no. Your report simply contains notifications that don’t match your flow, so you’re not receiving them. The app runs smoothly on the latest version here.
@LRvdLinden can you see if something is wrong with this rapport?
2ee7cccd-b314-476c-b951-deb46d5f0f55
here it also doesnt work. when using for example the P2000 tag in a THEN card, it says
Invalid Token: homey:device:XXXXXXX-XXX-XXXX-XXXX-XXXXXXXXXXXX|p2000
(without the X’s but removed the original key)
@Dnhaas Do you have a example of your flow.
Maybe someone can see if there is something wrong.
Hi everyone,
I noticed a limitation with the condition card when filtering by priority in the P2000 Homey app.
The condition card currently offers 5 priority categories. However, when an ambulance is dispatched for either an A0 or an A1 call, both are reported as Priority 1 within the app. Because they share the same priority number, it is currently impossible to filter flows specifically between A0 and A1 dispatches.
Would it be possible to split these priorities or add a categorie so we can separate A0 from A1 calls in my flows?
Can’t you just use a Homey default logoc card and look for the P2000 message and search the priority to A0?
Yes, I have that now. “if the message contains A0, A1, A2, etc.”
However, If, for example, an incident occurs on the A12 or A2 highway right now, it is given that priority.
Because the P2000 message contains all the information about the incident.
If you follow my example, you won’t receive notifications for the A12 highway, only incidents with priority A0, A1, or A2.
Nope, that doesn’t work. As I mentioned earlier, the P2000 message contains more data than just the priority.
If you say “P2000” equals A0, that card will always evaluate to false. That’s because the logic contains more than just A0, A1, or A2.
We (@martijnpoppen) just deployed A0 into prio 1.
I’m no longer receiving any notifications, even after deleting and reinstalling the app. What could be causing this?
