[APP][Pro][Cloud] P2000 for Homey (Dutch 112 (911) alerts
Hoi Mike, Dit was de oplossing! Dankjewel! Op een of andere vage reden waren de devices verdwenen.
for now I just created a flow that the app is restarted every 2 hours. this way you don’t miss anything and @martijnpoppen and @LRvdLinden can look for a solution :fire::+1:
Here also was the solution to reboot the app then the messages will come in
We have a fix for it. I will push it within 10min.
:sparkles: Live 4.2.2
New live version! (Reboot the app after update)
FIX
  • Keep app alive
Download the new version in the Homey App Store!
More - apps - P2000 - settings wheel right top - send diagnostic report (put your email and issues in the input field to make it easier)
Hmm thought rebooting was working but it looks like it does not
:sparkles: Update 4.2.3
New live version!
FIX
  • Message timing improvements. This will prevent messages from passing through your set conditions that do not comply with them.
see picture advance flow, it doesnt work, plse help :slight_smile:
when testing, it will stock on “Dienst is …”
You can’t test the P2000 flow. Wait till there is a P2000 message came in on your whatsapp.
I did the last few days, but no messages came in the whatsapp.
this mornig there was a message on p200 for rozenburg but no message was sens to whatsapp
Hi @Rini_Lurling .
Start your flow without any filtering.
It will only take a few seconds to then have at least one message received.
Then filter down 1 step further.
Etc.
Are you on app version 4.2.3? Reboot the app P2000 pls and make a whatsapp card with a direct connection to the trigger card. To see if it works. There are no issues on the database site.
Hi yes i have version 4.2.3, and reboot the app.
With a test from trigger to send message worked.
With and card, dienst ambulance and regio rotterdam rijnmond it worked
now i try again with Rozenburg as and card at the end :slight_smile:
@Rini_Lurling I have a question about the filtering of all the “Dienst”. You are sending the message to a WhatsApp number but are you using 10 different Wharsapp numbers?
If you ad the card “Dienst” at the WhatsApp card you know what Dienst has get the message. Or am I wrong?
Your city is wrong. Just only wright Rozenburg.
@Mike1233 nope one whatsapp number, all messages send to that number
Make one whatsapp card en connect it to all services
@LRvdLinden Hi Leon, already test that as well.
There are two Rozenburg in the netherlands one Rozenburg regio Rotterdam (ZH) and one regio amsterdam (NH)
Delete zh and use province condition card before or after your city. Rozenburg ZH is still wrong.
Hi Leon,
thats a good one :slight_smile: didnt think of this. Thanks i wil try
Thanks for the help
