My bad,
my english is not perfect.
You are right, because here netatmo explain that they retrieve the data shown in below picture from their partnerAerisWeather, anyway is possible to show this values?
@MarcoFrax -
Thanks for the detailed answers and the pictures.
As for the Air Quality coming from partnerAerisWeather, I will not be able to add it to the device since I can only see the metrics that are provided by the device itself, and I can not see metrics collected from other sources.
I saw that the “Open Weather” app for Homey (OpenWeather App for Homey | Homey) is capable of providing Air Quality information, maybe it can help you find what you need.
As for the CO2 - you are right, it’s a mistake of mine - I will fix it in the next version I release (hopefully next week). Thanks for letting me know!
Both are correct:
The Smoke and CO detector is monitoring CO
The Netatmo Weather station is monitoring CO2
I made the proper fixes to the app (I only had to change the Smoke detector), it will be a part of the next release (hopefully next week).
I’ve been using HomeServer1 with Bticino products, and everything was working perfectly. However, all my devices are now unreachable. When I try to repair the connection, I receive the following error message:
Your Homey has a connection problem and it can not reach Netatmo’s servers.
I have seen several connection issues recently, seems like Netatmo can’t handle the high load again (it happened several times in the past).
Sometimes, restart to your Homey can work. Try restarting your Homey and see if the issue is resolved.
If not, send me diagnostics report (app settings → send diagnostics report).
Recently, it seems that Netatmo cloud servers can not take the high load again, and I can see many failures in my app.
I just released version 1.1.44, which has a fix to this issue.
If you see any problems with the app, please follow these guidelines:
Make sure you were upgraded to version 1.1.44 or higher (you can upgrade manually if you were still not upgraded automatically)
Remove ONE of your Netatmo devices from Homey. You have to remove only one, not all the devies. It doesn’t matter which one you choose.
Add the device again to Homey
Wait for 2 minutes for the change to take affect
This will refresh the token acquisition logic and should fix the problem.
If you still see issues after these steps, please send me diagnostics report with a comment explaining the problem you are seeing.
@Vincent_T - Sorry I missed your questions, but I can see you managed to send the report.
For now, everything seems to be working fine in your environment.
Once things are broken again, please send another report so I can see what happens when its nt working. Please do not remove/re-add a device so I can see the problem.
Please don’t forget to put your name on the report’s comment.
I’ve exactly the same problem since 2 days with all my legrand/bticino equipment. Any news about this problem ?
And the problem is only in Homey. With vocal command directly on Alexa, all work perfectly.
Here is my diagnostic report number : a23ba35c-a064-4a27-9877-fa968a48d129
