[APP][Pro] Better Logic Library - For Users
If you are an App Developer and want to know more about how to include this into your App or how to let your App support BLL coding, goto the [APP][Pro] Better Logic Library - For Developers Forum Topic.
This Topic describes the app for Users.
Homey’s first real Library: Better Logic Library!
Welcome to the Better Logic Library.
An advanced logic library with variable and library management for Homey.
This apps supplies your Homey with Better Logic and Libraries:
  • Variable management in a smart, integrated way.
  • Advanced action- and conditioncards with Better Logic, like Math.js.
  • Devices to directly manage the variables.
  • Datetime formatting, fully customisable, shared with other apps.
  • BLL coding and BLL expressions to use directly within other apps flowcards.
  • Custom functions to use within BLL coding and BLL expressions.
  • Libraries to use within BLL coding and BLL expressions, like Math.js and Lodash.
  • A File Server that can be consumed by other apps, like Simple (Sys) LOG, to serve files on you LAN or to download them on the Homey Mobile App or the Developertools.
  • Libraries for other Apps to consume, reducing app sizes and redundancies and improving management.
  • APIs for variable management, using the File Server or other BLL functions.
Check out the (new) App Settings for all features and explanations, like BLL coding in supported apps!
BLL Coding
Within all flowcards that supports BLL coding, you can add any BLL expression within the next codeblock: {[ expression ]}.
You can use this f.i. within the Save Image Token flowcard from the FTP Client App
This image will be saved with the custom timestamp the user writes himself:
Old Topic:
[APP][Pro] Better Logic Library - Just some better logic, variable and library management
Please report issues or feature requests at Issues · Qluster-IT/nl.qluster-it.BetterLogicLibrary.
Apps:
Donations or Sponsorship
App Settings
Here is a description about the new App Settings in the Better Logic Library App.
Variables
Here you can add, edit and delete variables.
To add a new variable, click on Add variable to open the new variable card.
Coding
Here you can see how to use coding and try examples.
Click on the Example (eye) to show the usages down below, which is also shown in Locale/TimeZone by default.
Locale/TimeZone
Here you can configure the locale or language and timezone to use by default for coding.
  • Within coding you can always define a locale or timezone.
Formats
Here you can alter the definition of any default datetime formats for the default locale.
This will be applied to every app using the BLL coding or DateTime.
Functions
Here you can add functions that you can use in expressions and BLL coding.
BLL Coding
BLL codings are expressions within text-arguments in flowcards.
In every App that supports BLL coding, for each text-argument in flowcards that goes through the BLL decoder, you can use {[ expression ]} .
Within these expressions, you can use build-in modules, functions and your own customisable functions.
Modules
  • _
    Lodash 4.17.21
  • math
    Math.js 11.3.3
Example
The last one is: {[ _.last(["1", "2"]) ]}.
Result:
The last one is: 2.
Build-in functions
date(format, date?, locale?, timeZone?)
This method will return the current date(time) in the entered format, with respect to the user defined locale (language) en timezone.
Optionally you can supply the date(time), locale and/or timeZone.
Example
Today is a {[ date("dddd") ]}
Result:
Today is a donderdag
Date codings:
Apps that support BBL coding in (certain) flowcards:
BLL coding, see the App settings to get a better view on what that is and how to use it.
Device Capabilities
Device Capabilities supports BLL coding in Set Text and Set Status text-arguments, in the Set field to BLL Expression and ofc in AVD Reflection.
FTP Client
FTP client supports BLL coding in all it’s text-arguments, like saving an image to FTP:
Google Services
Google Services supports BLL coding in all it’s text-arguments, like Start saying […]:
The number method
Within BLL coding or expressions you can use the number method to convert numbers into text, based on your (or another) locale/language.
It supports overloading, and can be used the following ways:
  • number(number, decimals?, locale?)
  • number(number, style?, decimals?, locale?)
  • number(number, style?, styleOption1?, decimals?, locale?)
  • number(number, style?, styleOption1?, styleOption2?, locale?)
  • number(number, style?, styleOption1?, styleOption2?, decimals?, locale?)
There are 4 styles (decimal is the default):
  • decimal
  • currency
  • percent
  • unit
Decimal
Styleoption1:
  • standaard
  • scientific
  • engineering
  • compact_short
  • compact_long
Styleoption2:
  • standaard
  • noGrouping
Currency
StyleOption1:
  • Any valid currency, like USD or EUR
StyleOption2:
  • symbol
  • narrowSymbol
  • code
  • name
Percent
Has no styleoptions
Unit
StyleOption1:
  • acre
  • bit
  • byte
  • celsius
  • centimeter
  • day
  • degree
  • fahrenheit
  • fluid-ounce
  • foot
  • gallon
  • gigabit
  • gigabyte
  • gram
  • hectare
  • hour
  • inch
  • kilobit
  • kilobyte
  • kilogram
  • kilometer
  • liter
  • megabit
  • megabyte
  • meter
  • mile
  • mile-scandinavian
  • milliliter
  • millimeter
  • millisecond
  • minute
  • month
  • ounce
  • percent
  • petabyte
  • pound
  • second
  • stone
  • terabit
  • terabyte
  • week
  • yard
  • year
StyleOption2:
  • long
  • short
  • narrow
API
Is it possible to add the “GMT +1” part separately?
F.i. Homey locale is English,
but I want to use 24h time, without changing the BLL locale to Dutch.
HH:mm:ss but what is the code for GMT+1?
I know, it’s cool right :slight_smile:
But just added to test:
KK
kk
hh
h
tt
ISO
No fixed GMT+ yet, that will only appear with KK or kk when you have a locale of EN f.i…
(So for you, this will show GMT±, for me it shows CET).
Fixed GMT+ will be Z, but no luck yet to complet this part without adding external node-modules.
And i don’t want that, they are all a few MB, while my custom solution is less then 20kb.
Example on how to use a BLL expression
In this case the date method:
You can also create default functions/methods in the App Settings (Test version) and use those in these expression flowcards (or BLL coding).
Thank you for continuing development of this great app!
I upgraded from the legacy Better Logic today and there seems to be an issue with Math.JS condition card. As POC I created T1 and T2 booleans and a test flow.
https://homey.app/f/luscxi/
If Math.js expression is true. All variants of T1 and T2 being true of false is considered false.
If Math.js expression is false. All variants of T1 and T2 being true of false is considered true.
\ Andreas
Hey, i’ll look into it as soon as i am able.
Could you please create a ticket at bitbucket for it?
QlusterIT / nl.qluster-it.BetterLogic / issues — Bitbucket
Thanks!
Thanks a bunch.
Ticket created: QlusterIT / nl.qluster-it.BetterLogic / issues / #7 - Math.js expression not validating — Bitbucket
Not sure if this is the same issue and all mathjs calculations are effected, but my BL math.js calculations does not seems to work anymore since november 14. The calculation is quite simple, it is for calculating the costs of a dishwasher cycle
Checking it right now. One moment please.
@aste and @Julian
Solved in the current/latest Live version.
I updated to the latest math.js a few weeks ago.
Internally not different, but the evaluation call itself was changed.
Thanks for the quick reply & solution!
Works like a charm. Tnx for your quick resolution!
There seems to be a bug in Math.js not validating Equal
something == something
is always false.
I’ve tried with and without ““ to no avail.
https://homey.app/f/5nAeXj/
and an even simplier version
https://homey.app/f/drmgXj/
Bitbucket bug: QlusterIT / nl.qluster-it.BetterLogic / issues / #9 - Math.js not validating Equal — Bitbucket
Thanks for reporting!
I’ll have a look asap, somewhere next week.
You probably already know, but you can do this function also with a Logic card.
