Hi all,
In a advanced flow I would like to have the date as yyyy-mm-dd, but I just cant get it to work.
Does anyone know how to get this working? I would like t get a text -tag as output for the next flow block.
Best regards,
Hi all,
Best regards,
You can get formatted date with:
Hi @OH2TH,
Thank you for the reply. I have seen the card with the BLL expression but I cant get the expression in such way that it’s accepter. It just outputs the expression as text.
Oh wait i dont use the ‘[’ brackets… let me try it out first.
Best regards,
hi @Peter_Kawa ,
It seems that the date format is region depending. I only have dd-MM-yyyy.
Best regards,
Just type in the box yyyy-MM-dd
Once it is there, you can select it as a custom format. Just as @Peter_Kawa wrote above.
Hi @OH2TH ,
Strange now the format shows up. It did not before ![]()
Thank you for your help.
Best regards,
