[APP][Pro] Balboa
Thanks for letting us know!
Hmm, the CMS app seems to be back online, but can’t retrieve the status of my spa nor control anything. Says «Unavailable» in the CMS web app. Anyone able to do anything or is it still not operational?
Seems like it’s not operational yet… :frowning:
Partially available now. At least I am able to connect, but can’t control anything. Seems to be “read-only”. What does the API response indicate @martijnpoppen ?
@Grath no idea
Dont have a spa myself :wink:
If youre willing to share your credentials with me I can check
It’s not working. Do you need some information from me?
If you could share your account temporarily then I can check the API
I also tried the controlmyspa app using the test credentials I have (not sure if they still work) but the app also gives errors.
But might be the credentials. API is also throwing errors
How can I get it?
Theres no share option or something like that. Its just you have to share your login with me.
Only if you want to ofcourse
I agree. Would be really useful to control filter cycles based on electricity prices.
Hello. Very keen on getting the app to work, but it does not find my spa.
I have a working Balboa acount and can connect through the native app. When signing up for cloud controll it only let me create a username with letters, not an email address. Your app ask for an email adress for signing in?
Hey @Audun_Sivertsen
Are you using the controlmyspa app or BWA app?
Did not find any other then the ControlMySpa
Is it in the app store?
I have a Balboa control on my spa
@Audun_Sivertsen i mean which app you use on your phone (not Homey)
Balboa has 2 wifi controllers:
  • The BWA module
  • The controlmyspa module
Sorry. The bwa
@Audun_Sivertsen BWA is not compatible with this app.
For BWA there are no Integrations for Homey.
Ok. Thank you. Is the app based on direct comunication with the spa or throug the cloud service?
Controlmyspa trough cloud
BWA should be direct communication
New app update (test: 1.6.0):
1. NEW: add flow triggers:
  • Pump State 1 changed
  • Pump State 2 changed
  • Pump State 3 changed
  • Light State changed
  • Blower State 1 changed
  • Blower State 2 changed
  • Blower State 3 changed
  • Temperature range changed
  • Heater changed
  • Online state has changed
  • Is ready state has changed
  • Temperature range has changed
  • Heater has changed
FYI: @Bono_van_der_Pasch
If you want to check it out you can click the link above and install the test version.
