[APP][PRO] Balboa-Spa - 50350 WiFi Module
Balboa-Spa
For the 50350 WiFi module
Note: App in early development!
Welcome to the early testing phase of my Balboa-Spa App! This app allows you to control your Balboa Hot Tub equipped with a 50350 WiFi module. Designed for Homey Pro, it operates seamlessly over a local connection to your hot tub.
Features:
  • Real-time spa status
  • Set temperature and range
  • Control lights
  • Water freeze alert
Languages:
  • English
  • Dutch
  • Danish
  • Swedish
  • Norwegian
  • Italian
  • Korean
  • Polish
  • Russian
  • Spanish
  • French
How to Use:
  1. Download the Balboa-Spa app from the Homey App Store
  2. Add a new device with Balboa-Spa App, select the 50350 WiFi Module, and it will scan your LAN
  3. If the module is found, add it to Homey
  4. Start managing your spa from your Homey Pro
Special Thanks:
A big thank you to everyone who has published their Python projects integrating with the 50350 WiFi module. Without your contributions, I wouldn’t have been able to work on the compatibility with Homey.
Support:
Have questions? Leave a comment below or open an issue on GitHub.
Donation:
I code better with caffeine. Probably.
:hot_beverage: buymeacoffee.com/Swedlund
Works very good! Right out of the box. Just add the WiFi module and create flows to control the spa.
Tried to send commands from BWA-app (pumps) and the app showed it immediately, it worked flawlessly.
Thanks a lot, Ralph! :folded_hands: Really glad to hear you like the app.
works great. Have you any plans to extend the flow capability that all parameters (blower, temperature etc) can be changed using a flow? In addition a flow trigger if any of those parameters have been changed using the spa would be super! I would like to use the app to establish a KNX Connection where I need events (flows) to modify data and events if data has been modified (including the actual value). Best, Frank
Hi Frank,
Thank you so much! :folded_hands: I’m really glad to hear that you appreciate the work on the app.
I will definitely look into your suggestions regarding more flow cards for conditions and triggers, and I hope to get an update out soon.
However, I wanted to let you know that I have recently moved over to Home Assistant myself. Because of this, the upcoming update will likely be my last contribution to the app. I will make sure the code is available on my GitHub so that others can continue to develop it and add new features.
I have installed this app and I’ve communication with the Spa. However in a flow I have only 2 then cards. Is it possible to change the temperature in a flow
Hi JRO,
The app currently has limited flow card capabilities. As soon as I manage to get my dusty Homey up and running again (it died 2 weeks ago), I’ll look into adding some additional flow features.
Any progress regarding the temperature? The app is working very well regarding connection and response but it really needs the possibility to change the temperature, for the whole range 10-36 in Low heat mode and 25-42 in High mode. Would you be able to make these changes to the app and make these set cars available?
Thanks in advance
Hi Anders
I’ve just released version 1.2.1 with “Then Cards” to change the heat mode between low and high, as well as set the temperature using flows. You should now be able to switch to for example low and then adjust the temperature within that range. I haven’t found any way to control the low temperature range while high is active, so the spa needs to switch to low first before the temperature can be set for that level.
This version is very lightly tested, so be prepared that some things may not work as expected
Hi
OK, thank you for the update, good news :+1:
This is OK, we just add an extra step in the flow of switching between high and low then changing the temperature.
Thanks for your effort
I have tested the new version and what I have seen it works flawlessly :ok_hand:t2:
Great work!
I’m very pleased with the application overall. The app works well, and the connection has been stable without any issues.
However, since the latest update, I am no longer able to control the blowers of the jacuzzis through the application. Before the update, this functionality worked perfectly.
Could you please look into this issue?
Thank you in advance for your support.
