Howto use Balboa Worldwide App (APP) with local spa control
While the [APP][Pro] Balboa handles very well the cloud based ControlMySpa (CMS) and Balboa BWA cloud connected devices. I do prefer local connectivity and control of devices. For quite some time I have had CMS for automating the spa heating and other routines. But lately Balboa has been making changes on their API and of course the community app will break. In addition the CMS service has been occasionally unreliable.
So, I bought a BWA Wifi adapter also and plugged it in the spa. The spa has a RS-485 bus which allows nicely multiple controllers on it. Now the normal control panel, CMS and BWA are happily controlling the spa.
BWA has local TCP port open and there is a Ruby app that can bridge the device to MQTT with Homie Convention compliant topic structure. GitHub - ccutrer/balboa_worldwide_app: Ruby library for communication with Balboa Water Group's WiFi module or RS-485
First I tried to use https://homey.app/a/nl.hdg.mqtt and it’s Homie Discovery device, but that has it’s limitations on device capabilities as it allows only the standard Homey capabilities.
Here is how I set it up
Install Balboa Worldwide App gem
First install Balboa Worldwide App gem as described MQTT/Homie Bridge on a spare Raspberry Pi
> sudo apt install ruby
> sudo apt install ruby-dev
> sudo gem install balboa_worldwide_app
> sudo curl https://github.com/ccutrer/balboa_worldwide_app/raw/main/contrib/bwa_mqtt_bridge.service -L -o /etc/systemd/system/bwa_mqtt_bridge.service
Modify the /etc/systemd/system/bwa_mqtt_bridge.service fot the MQTT server and the target BWA device:
[Unit]
Description=Balboa Spa MQTT Bridge
[Service]
ExecStart=/usr/local/bin/bwa_mqtt_bridge mqtt://localhost/ tcp://bwa_spa_hostname_or_ip:4257/
Environment="LOG_LEVEL=WARN" "LOG_VERBOSITY=0"
Restart=always
RestartSec=3s
Type=notify
NotifyAccess=main
WatchdogSec=60
[Install]
WantedBy=multi-user.target
In the above the mosquito mqtt server happens to run already on the localhost, you will need to allow anonymous connections from localhost. Replace bwa_spa_hostname_or_ip with your spa’s hostname or IP-address. Used fixed IP for the bwa wifi adapter.
There is also a user=cody in the file for the service’s run as user, remove that.
Finally enable and start the bridge service:
> sudo systemctl enable bwa_mqtt_bridge
> sudo systemctl start bwa_mqtt_bridge
Configure a new advanced virtual device with Device Capabilities
Configure [APP][Pro] Device Capabilities - Enhance the capabilities of devices to add an advanced virtual device for the various capabilities published by the BWA Bridge to MQTT:
I mapped the homie/bwa/spa/ topics as Virtual Device capabilities:
Topic Data type Settable Format Device Capability Type Show as Capability Name
heating-mode enum x ready,rest,ready_in_rest Button On/Off (Button tab) Heating Ready Mode
heating boolean true,false Button On/Off (Button tab) Heating
temperature-range enum x high,low Button On/Off (Button tab) High Range
current-temperature float 0 - 42 Numberfield Temperature (Measure) Temperature
target-temperature float x 10 - 40 Numberfield Temperature (Target) Target Temperature
circulation-pump boolean true,false Button On/Off (Button tab) Circulation
pump1 boolean x true,false Button On/Off (Button tab) Pump 1
pump2 boolean x true,false Button On/Off (Button tab) Pump 2
pump3 boolean x true,false Button On/Off (Button tab) Pump 3
light1 boolean x true,false Button On/Off (Button tab) Light
For the buttons that have unsettable topics, use also the Non-Clickable option.
Using MQTT Client to connect the topics the the device capabilities
To talk with the MQTT server you will need the MQTT Client | Homey app configured for your environment.
Then using advanced flows setup a number of topic triggers and actions from the device capabilities.
Read-only status information
The state of heating and the circulation pump are read only values, so no need to catch a trigger. Don’t forget to set those as Non-Clickable in the AVD.
Water temperature
I have a ESP32 with DS1820 sensor to measure the exact water temperature and report it a bit more often than CMS nor BWA will do. CMS reports at 1 degree resolution and BWA 0.5 degrees.
So I have a special flow to update information from that.
Target temperature
Values from BWA to AVD
Values from AVD to BWA
Heating mode and Temperature Range
Pumps 1 - 3
Number of pump controls varies on your spa, mine has three some may have less.
Repeat for the number of pumps you have.
Light
Some Thoughts
Booleans Handling in Homey
For some really strange reason, Athom has decided that true or false value is presented as special ✓ or ⨯ characters with value is transformed to a text value. That is the reason you can’t use the boolean value from the When Capability is changed trigger card but have to use a logic card to decide of a true or false string is sent to the MQTT topic.
Even a simple logic comparison has to be done as a string comparison with Better Logic Library!
Avoiding Bouncing - Setup Debounce
When a MQTT topic is received, there should be check to see, if the value is already set on the related AVD capability. This would stop unnecessary update from AVD to MQTT. For example:
I am developing a custom web interface and wifi module. I have all working but I saw that with ControlMySpa there is option to change colour of leds. As I can see that you have this CMS device, can you please check the buffer for changing these colours when the API call is made?
Yes, I have CMS also, but this topic is about using BWA and local API. I am not aware of controlling the color of leds by CMS nor BWA.
this is what i am trying to achieve last weekend but not succesfull unfortunately: I’ve been trying to integrate my Balboa spa (with the BWA™ WiFi module) into my smart home setup so I can automate heating based on solar energy. The idea is to heat the water during sunny moments and lower the temperature at night when I’m not using the spa.
I use a Homey, but unfortunately, the Balboa Homey app isn’t stable for me — it loses connection often and requires me to log in again each time.
What I’ve tried:
  • The spa’s WiFi module is working and reachable at IP 192.168.2.65
  • I run Mosquitto MQTT broker on a Raspberry Pi (192.168.2.43) — it connects fine via MQTT Explorer
  • I use a Python script (balboa_mqtt_v2.py) to send discovery/status packets over UDP port 4257
  • Using tcpdump, I’ve confirmed that the UDP packets are sent correctly to the spa
  • Unfortunately, the spa never responds to these packets — even when the BWA mobile app is completely closed
What I suspect:
  • The WiFi module might only allow one active client (the BWA app)
  • Or it blocks non-official communication (e.g., by filtering MAC addresses or through firmware restrictions)
