nice @Kjetil_Vert ! ![]()
yes now I only need to get you to update your app or I would also need to reversenginer that to ![]()
@Kjetil_Vert i’ll check when I have time ![]()
Great stuff if you need any more then joust ask ![]()
Might be able to help, I’ve got also the BWA module in addition to CMS.
Would be interested in the local API of the device to remove cloud dependency.
Goedemorgen,
In de Balboa app " ControlMySpa" wil ik graag de circulatiepomp laten draaien. Kan alleen kiezen “Circulatie pomp status veranderd”. @martijnpoppen, heb je een tip hoe ik deze kan aansturen?
Alvast vriendelijk bedankt!
@Franko71 please type your message in english as this is a english topic of the forum.
There’s no way to set the circulation pump. That’s also why there’s no flowcard for it ![]()
Ok thanks Martijn, thought maybe it will come or can be activated.
Ps holiday coming up if you need help I have fix the script and made a funtion for each update so that all you need is to implement this as a extra call in your app based on the different login and version. ![]()
Also I have it now running as a virtuel thermostat so that I can play with it like a app and not only a script.
This also gets then pushed to apple homekit ![]()
@Kjetil_Vert already started a bit. It will be a separate driver in the app. And the app will be renamed to Balboa ![]()
Then you can chose between BWA or CMS and both have their own functions.
I don’t think it will be much work with all the stuff you did !
I’ll let you know when it’s testable!
Great stuff
Looking forward to testing this ![]()
Here is a updated homeyscript I use and cleend up a bit ![]()
@Kjetil_Vert can you maybe share your homeyscript as a snippet? copy pasting doesn’t work properly like this.
you can do that by wrapping the above message between ```
or did you update the script already in Balboa BWA Spa script ?
yes I did update the Balboa BWA Spa script
I will update my post above withe the link
Hmm, need to finally install bwa controller in the spa.
@Kjetil_Vert do you maybe want to share your credentials temporarily with me? That I can test it out?
Went trough your file and I think I can make it work, just checking for updating of data to sensor tab etc.
But would be nice to test with real data ![]()
If so please send me a DM ![]()
Oh, but that uses the cloud API. Was thinking on local interface of the Wifi module:
@OH2TH yeah that one is the difficult one ![]()
New app update (
TEST: 2.0.3):
Changelog:
NEW:
1: BREAK: App rebrand to Balboa
2: NEW: add Balboa BWA
3: NEW: improve login screen
More - apps - ControlMySpa - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
@Kjetil_Vert see update above. Can you test it? ![]()
you can install by clicking the version number and then the green install button
Tried it now, install is fine but no values from spa is reported to app
