[APP][PRO] Aseko Pool dosing systems
Aseko does not provide a realtime interface thru the API so that is impossible. Looking to get it more close by polling…
1.4.2 is now live, should poll every minute. Also should fix the errors you see now, i am not getting these, so a bit of a guess what was going wrong.
Hi Martin, i recently have bought the Aseko ASIN Pool PT1000 control-unit and the Aseko ASIN Aqua NET. Both devices are controlled by an separate App (Aseko Pool Remote and the Aseko Pool Live). In the picture, when i install your Homey App, i see the controle-unit PT1000 but the controllers in the App suggest that only the ASIN Aqua is programmed by you ? Thanks, Alexander
Dobrý den Martine, mám již nějaký čas Aseko ASIN Aqua SALT, který s Vaší aplikací funguje perfektně, za což moc díky. Nicméně minulý týden jsem dokoupil i Aseko REMOTE (je to ta jednotka, která je na obrázku na webu Homey jako "Supported devices - Asin pool unit) a Vaše aplikace už to nepodporuje. Mohli bychom si třeba zavolat nebo psát přes maily a zkusit to spolu naprogramovat? Přístupy Vám rád poskytnu. Předem díky, Lukáš Král… 725 501 769, mail: lukas.kral@konsilio.cz
Sorry, no clue what the message says. Could you please state it in English or German for me?
I´m so sorry, I think your name is Czech… :grinning:
I’ve had the Aseko ASIN Aqua SALT for some time now, which works perfectly with your application, thank you very much for that. However, I also bought an Aseko REMOTE last week (it’s the unit that’s on the picture on the Homey website as "Supported devices - Asin pool unit) and your app doesn’t support it anymore. We could maybe call or email each other and try it together setup it? I will be happy to provide you my access.
Thanks in advance, Lukáš Král… +420 725 501 769, email: lukas.kral@konsilio.cz
(I spreche besser deutsch als english)
can you PM me the serial number of the remote unit?
Hi, I am also considering buying the Aseko ASIN Aqua NET. Did you or anyone else get this to work with this Homey app? (for me reading temperature is most important to control the heater, though other levels are of interest)
BIG CHANGES TO ASEKO APPS AND API THAT MIGHT DISABLE THE FUNCTION IN OUR APPS AND CONNECTIONS WITH SMART HOME INTEGRATIONS
@Martin_Verbeek
Aseko has sent an email saying:
September 10th to 15th, 2024, we will be releasing significant updates to the Aseko POOL Live and Aseko POOL Remote apps. These updates are essential for the continued use of ASEKO applications. Without installing them, the apps will no longer be functional.
Please visit my post and make your comments on this. It would be great to see how many of you that will be affected by this.
Link to the post regarding the Change
So should we wait until next year? there is probably no other chance :frowning:
Currently not at home. But i have been looking at the new app in the browser. Did some first changes, might work but not sure yet. More news in a couple of weeks
Glad to hear that it sounds promising. After the app/API update no values have been read by Homey from Aseko. Before it worked like a charm. Tried to remove and reinstall the Aseko unit, but it is no longer recognized. Looking forward to the updated app and if you need any help testing it I would be happy to assist.
First attempts are promising, Aseko has completly changed the implementation, so it will take me some time.
Any progress on adapting to the new api?
I was rather hoping to connect my Aseko Home as well.
I’m sorry for nagging, but pool season has started and I’m really missing the great integration with ASEKO you created to keep an eye on that everything is running smoothely. Have you been able to make any progress?
Thanks in advance for the work you put down.
Thanks for updating the app. It now runs flawlessly and looks beautiful. :star_struck:
It seems like Aseko has changed the mode of integration. Since three weeks ago I don’t get any data to Homey. In the Aseko app there is now a possibility to generate API keys.
Are you planning to update further?
They are very busy changing things :expressionless: need to check if possible. Will let you know
Martin, thanks for what you are doing for the community. I know you likely do this for fun and not money, but I would anyway very much like to contribute a couple hundred euros if we can get the integration going again. Given Aseko seem to have got the documentation at least up and running, do you think it would be possible do get the API key thing going? For me (and assume for many) it is primarily temperature which is critical for controlling heating via Homey, while ph/chlorine levels etc is nice to have (as the Aseko app can give alarms on that ). https://api.aseko.cloud/api/v1/docshttps://api.aseko.cloud/api/v1/docs
